Amp install question
Discussion in 'Audio & Video' started by Fiddynut, Dec 30, 2011.
  1. Dec 30, 2011 at 11:39 PM
    Fiddynut
    Fiddynut [OP] Well-Known Member
    San Diego
    03 TRD Double cab
    Bilstein 5100s on 32" BFGs
    I'm going to install some new speakers and an amp using my stock HU. What do I need to interface the amp with the stock HU? Does someone make a plug and play type?
    I have an 03 double cab
    Thanks in advance!
  2. Dec 31, 2011 at 12:02 AM
    Hondarider08
    Hondarider08 "That's what she said..."
    Justin
    Logan, UT (Originally Pocatello, ID)
    05 Tacoma TRD
    Leveling kit, K&N drop in, and a Loud Ass Stereo :)
    You're going to need a line output converter. It's not necessarily "plug and play" but it's pretty simple. Some some basic splicing is all that's needed. What it does is takes the speaker wire output from the deck and converts it to an RCA style output. These are used for decks without pre-amps (i.e. the OEM deck).
    Here's a four channel one on crutchfield. They also make two channels as well.
    http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html?search=line+output+converter
    Let me know if you have any more questions.
