Amp mounting with eBay dual 10" sub box?
Discussion in 'Audio & Video' started by CrazyDiamond, Apr 7, 2013.
  1. Apr 7, 2013 at 10:39 AM
    CrazyDiamond
    CrazyDiamond [OP] Active Member
    2011 4x4 TRD / DC / SB
    I'm looking at a dual 10" sub box online (1/2 price audio) for my '11 double cab. I'm trying to determine if I can mount my 4 channel amp vertically between the subs. Specifically, I'm curious about the thickness of the amp and the ability to latch the seats.
    Can anybody comment? Got pics?
  2. Apr 8, 2013 at 7:41 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Need the amp measurements before I could even guess. I have a Kenwood XR-5S mounted horizontally, but I did attach some wood to fill in the lower part of the amp board "step", such that I could attach the amp using all 4 mount points.
  3. Apr 8, 2013 at 9:19 AM
    Aw9d
    Aw9d That one guy
    Az
    Was able to fit a Alpine 5 channel amp just fine on that box. Used thread through bolts/nuts and mounted it that way. Worked great.
  4. Apr 8, 2013 at 9:37 AM
    tacomatrdod
    tacomatrdod Well-Known Member
    Mud Country
    2010 tacoma trd offroad
    Toolbox, stereo upgraded a tad
    AN alpine 1700w, class d block
    and a something or other smaller 4 channel probobally a kenwood, i just picked the most popular 4 channel for my speakers.
    I had to cut into one of the boxes for the class d, but alls well that ends with it thumping still, i just put allot of wadding where i had cut and am having no issues whatsoever.
  5. Apr 12, 2013 at 5:39 AM
    CrazyDiamond
    The box came yesterday. For the $$$, it's not too bad. The carpeting job was a little weak (a couple ripples where it wasn't smoothed out after gluing), but overall it is fairly well made.
    Here is the tight spot:
    My amp is just too thick. Cutting the box out in the center won't give me enough to clear the amp - this amp is just too long and too tall:
    I guess I'll look into putting the amp under the seat. It may be too long for that, too. This amp has inputs on both ends - which doesn't help. :( An old school Fosgate punch would be perfect here...
  6. Apr 12, 2013 at 6:13 AM
    CrazyDiamond
    Was this the JL Audio G1700 ?
    EDIT: Never mind - I measured the box and found a monoblock that should fit well enough. Looks like I'm running my subs mono in parallel now...
