Amp not turning on
Discussion in 'Audio & Video' started by Blaise22, Jul 22, 2009.
  1. Jul 22, 2009 at 4:30 PM
    Blaise22
    Blaise22 [OP] Well-Known Member
    Blaise
    California
    09 prerunner trd offroad
    Camburg 4.0 race spindles, coilovers, 285/75/16 Yokohama Geolanders mounted on 16" KMC Hoss wheels, Aero Turbine 2525
    Hey guys I just got my sub amp and headunit hooked up but the amp is not turning on the headunit works perfectly. Am I supposed to turn the amp on manually or is it supposed to automaticly turn on with the headunit? Its an alpine 450
  2. Jul 22, 2009 at 4:34 PM
    TightShirts
    TightShirts The StormTrooper
    TightShirts
    Phoenix... The Land of Lifted Trucks & Dirty Sluts
    08 Rugged Trail Ed
    Tint, Clear Bra, De-badged, In-Dash DVD, 09 Led Tail Lights, Chris4x4's old OME front shocks, 1.5" Deaver AAL with OME n182s, black billet in white sport grill, BHLM w/4500k HIDs + Fogs, bumper blackout
    you have to run a turn on wire from the headunit to the amp... then it will turn on automatically- it's sometimes labeled amp or power antenna on the back of the headunit
  3. Jul 22, 2009 at 4:35 PM
    BLUVVV
    BLUVVV LARGE Member
    Bryce
    Valley Center, CA
    11' A/C TRD O-R PreRunner
    flowmaster 40, blackout headlights, 10'' infinity subwoofer, custom rear enclosure, kicker mono amp. 5100's set at 2.5'', 32'' pro Comp Xtreme M/T tires, Pioneer dub din head unit, K&N CAI, MB Motorsports V-Drive rims
    check amp fuse
    check all the wires connected to amp as well as head unit wires connected to amp
    check ground
    check positive fuse
  4. Jul 22, 2009 at 4:37 PM
    TightShirts
    TightShirts
    08 Rugged Trail Ed
    first step is to get a volt meter and make sure the power wire is hot and you are getting some small voltage from the turn on wire... if not then start checking fuses
  5. Jul 22, 2009 at 4:40 PM
    Blaise22
    Blaise
    California
    I did still nothing
    How do I know if the fuse is bad? I connected the positive terminal while the key was in the on position could I have blown the fuse through this?
  6. Jul 22, 2009 at 7:13 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    you get a meter as someone already suggested and start checking to see where you have power. You could have a bad fuse, even if it does not look blown. It can separate at the end where you cannot see it.
  7. Jul 23, 2009 at 3:42 PM
    Blaise22
    Blaise
    California
    Thanks for the help guys both the fuses in the amp were blown, replaced them last night and have been blasting the hard hitting songs all day:D
