AMP Power Step Running Boards
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fjrmurph, Apr 8, 2011.
  1. Feb 28, 2012 at 8:38 PM
    flatfeet
    flatfeet Well-Known Member
    Rob
    Hilo
    09 TRD Sport 4x4 DBL CAB
    RCD 4.5 lift, 18x9 BFD, 305/60-18 Mickey Thompson ATZ's, projector HIDs, TRD exhaust, AFE intake, onboard air, led dash mod, train horns.
    Would it bust your shin if you were standing too close while opening the door?
  2. Feb 28, 2012 at 8:50 PM
    Cowboyz
    Cowboyz Membor
    Luke
    Southern Utah/Las Vegas
    07 DC LB TRD Sport
    6in Pro Comp stage 2 lift, 2.75in ProComp Coilovers, Rear MX6 adjustable shocks, 35in Nittro Trail Grapplers, 17 in XD Spys, URD intake, URD MAF Calibrator, Flowmaster 40 Series, AMP Power steps, debadged, blacked out tail lights, Blacked out headlights w/ Mini H1 Retros and halos, JVC KW-AVX840 7" Double-Din, Viper 5704 2way alarm/remote start, LEDs in Dome, Maps, and license plate lights, short black antenna, 5% Tint, removed sway bar
    Well in order to open your door you have stand back to get the door open.
  3. Feb 28, 2012 at 8:51 PM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    interesting. the seem nice and functional for street use
  4. Feb 28, 2012 at 8:56 PM
    Cowboyz
    Cowboyz Membor
    Luke
    07 DC LB TRD Sport
    I absolutely love mine. Not the best for offloading with mud. If your stayin on the streets you can't get better steps. Get more complements on them than any other mod
  5. Feb 28, 2012 at 9:08 PM
    flatfeet
    Rob
    Hilo
    Sorry, I meant if your garage was narrow and it was a tight fit. My daughter is 5 and barely reaches the door handle, is why I'm asking. Is there a switch to disable them?
  6. Feb 29, 2012 at 4:54 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Looks like they'd work good for door ding protection if you left them extended when parked. And does keyless entry trigger them or just the door pins when door is opened?
  7. Feb 29, 2012 at 9:41 AM
    Cowboyz
    Cowboyz Membor
    Luke
    07 DC LB TRD Sport
    No there is not a "switch" to disable them. once they are down you can put your foot on the step and shut the door and they will stay down. Great for when washing your vehicle.
    They are great for door ding protection, but no they do not open until you open the door.
  8. Feb 29, 2012 at 10:43 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Did you miss this in post #17?
    "And they have a safety feature that allows you to put them down with the door closed. if you put your foot on the step and close the door they will stay down. Great for when you are washing your truck"
    Wouldn't this work and allow you to walk away with them down until you came back got in truck and closed the door?
  9. Feb 29, 2012 at 3:58 PM
    Misfit
    Misfit Well-Known Member
    IL
    2017 SR 2.7L 4x4 5MT
    PcHearn..
    Could you possibly post more pics of the steps down and the doors open?
    It looks like because of the universal length for AC/DC that the DC rear passengers wouldn't have much to step on.
    Would it also be possible to move the entire step back so as to "Center" them on the truck?
    Thanks! :D
  10. Feb 29, 2012 at 7:07 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    This is mine installed.
    http://youtu.be/AouJFoKkwIs
    Sporttaco704 likes this.
  11. Feb 29, 2012 at 9:35 PM
    Cowboyz
    Cowboyz Membor
    Luke
    07 DC LB TRD Sport
    I'm the one that origionally wrote that.
    And yes you could leave them down and walk away and they will stay down until you reopen the door and then close it without your foot on them.
    But the only way to make the step come down is by opening the door. You could have problems if the keyless entry made them come down. Might hit someone walking by or someone waiting to get in your truck.
  12. Feb 29, 2012 at 9:37 PM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    These are kind of yuppish haha def dont get this if you offroad at all, If i saw you at a trail with these... Get ready for the shitstorm!
  13. Feb 29, 2012 at 10:11 PM
    Cowboyz
    Cowboyz Membor
    Luke
    07 DC LB TRD Sport
    You can move the steps forward or backwards to fit your needs. Once you loosen the bolts under the step you just slide it to where you want it and then tighten your bolts back up
  14. Feb 29, 2012 at 10:17 PM
    yamaha73
    yamaha73 Well-Known Member
    Royce
    Madera ranchos
    1997 4runner, 1980 Toyota pickup
    4Runner- wagoneer Dana 44 front lunchbox locker. Rear stock axle spooled. Beadlocks and 36s 3link rear, leaf front, dual transfer cases 1980 pickup- exo cage. Locked front and rear on 40s dual transfer cases. Custom paint job
    I had em on my old ford 250 and loved them I used em offload too
    mudding crawling and in the dunes never had a problem
  15. Mar 1, 2012 at 7:50 AM
    #35
    PCHearn
    PCHearn Well-Known Member
    Patrick
    Moore, OK
    11 PreRunner SR5
    Misfit - With ppham444's excellent video and Cowboyz explanation about moving the step, my pictures probably won't help. But if you still want to see them, they are in the Member Galleries under PCHearn. I guess you have access to my pictrues there. These steps are expensive, but they are the best ones out there.
  16. Mar 1, 2012 at 8:53 AM
    #36
    Misfit
    IL
    Thanks guys for the responses!
    Ideally I m looking for a top looking down picture of what you would see getting into the rear of the truck. Basically to see how much step is available to actually use.
    It would appear at first glance that the rear pass would be stepping on or near the end of the running board. If you moved it too far back then the driver might have the same problem?
  17. Mar 1, 2012 at 6:23 PM
    #37
    ppham444
    Phuong
    Portland, OR
    The running boards are long enough to fit people stepping into the front and back. Worrying about having to adjust it back and forth is not necessary.
    Looking down on the steps, you will fully see the steps. Remember, these steps swings down and away from the truck so you will fully use the width of the steps.
  18. Mar 2, 2012 at 7:12 PM
    #38
    PCHearn
    Patrick
    Moore, OK
    11 PreRunner SR5
    I have these running boards on my Tacoma. When I step into the front, my foot is about 18-20 inches from the front of the running board. When I step into the back, my foot is about 16-18 inches from the back of the running board. The back of the running board is even with the place where the back seat bottom meets the back seat back. In other words, if you draw a line straight down along the front of the back seat cushion (what you lean back against), that is where the back end of the running board is. According to Cowboyz, you could move the entire running board back about 6 inches. I believe it would actually look a little better than it does normally. But even if you leave it where it normally is, there is no problem at all with stepping into the back. I hope this helps.
  19. Apr 19, 2012 at 10:11 AM
    #39
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    Cool stuff there. subd for future money spending
    thanx for all the pics and the video is great too
  20. May 21, 2012 at 11:51 PM
    #40
    imprezzivesti
    imprezzivesti Member
    Is it possible to use these amp power steps with a 3inch body lift?? I really want them cause i'm at 12" lift and 37's with no rails right now but my girlfriend can't get in unless i help her up every time lol and i'm getting sick of it.
    I'm scared with a 3inch body lift these might look silly
