AMP Power Step Running Boards
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fjrmurph, Apr 8, 2011.
  1. Oct 22, 2012 at 5:22 PM
    #41
    Spot50
    Spot50 Member
    Bob
    Kansas
    2012 2WD V6 Prerunner
    Curtis Front End Hitch BaKFlip VP Tonneau cover Pop & Lock PL 8521 AMP Power Steps AMP-75142-01A
    With PCHearns and ppHam444 help, I've installed the AMP Running Boards and love them (took me much longer than 3-5 hours - but I'm 64). Question, with the controller in place, is it safe to wash the engine? Am curious if the controller could blitz out if water entered the top where the thing snaps together.
  2. Oct 22, 2012 at 6:46 PM
    #42
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Bob, I'm pretty sure they are water resistant, but if you want to be extra careful, just use a ziploc bag and cover it if you plan on washing your engine bay.
  3. Oct 22, 2012 at 6:56 PM
    #43
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
  4. Oct 23, 2012 at 5:37 AM
    #44
    PCHearn
    PCHearn Well-Known Member
    Patrick
    Moore, OK
    11 PreRunner SR5
    Yep, mine have LEDs.
  5. Oct 23, 2012 at 7:54 AM
    #45
    fjrmurph
    fjrmurph [OP] Well-Known Member
    When They are extended how far below the truck are they??
  6. Oct 23, 2012 at 7:34 PM
    #46
    Spot50
    Spot50 Member
    Bob
    Kansas
  7. Oct 24, 2012 at 9:39 AM
    #47
    fjrmurph
    Thanks
    I looked at the website but I didn't see that there
  8. Jan 8, 2013 at 5:48 PM
    #48
    ppham444
    Phuong
    Portland, OR
    Yes you can do it yourself! It'll take about 5 - 6 hours if you're a perfectionist like me.
  9. Jan 27, 2013 at 9:30 AM
    #49
    FrisbieTacoma
    FrisbieTacoma Active Member
    MO
    Lifted TRD
    Toytec BK0510 lift, 16x8 Mickey Thompson Classic II, 285/75/16 BFG AT, Clarion NX501, Ballistic seat covers, Weathertech floor mats
    I just installed these over the weekend on my 2011 ACC and I am very happy with how they came out. Looks great on the truck and they are very functional.
    The total installation time was close to 6 hrs. The safety feature on the steps is extremely sensitive. On the passenger side the linkage arms were slightly off putting the step into a slight bind on deploying. I had to adjust the linkage arms to get them to move freely. I also to shim the passenger (front and back arms) to get the step to line up with the rocker on the truck. Those were the only problems I had installing the steps.
    I only have a few complaints. The first is that the Tacoma kit is now made for the DC. The ACC owners now have to cut close to 10" off of the total length. I would highly recommend using a reciprocating saw for this. It cut through the step nice and easy and I did this once the steps were installed on the truck. For the price of the kit they could make 2 lengths available.
    Second is that when you open the driver door (or passenger) all of the LED lights illuminate. This would have been very easy to make door priority IMO. It should only illuminate the side that the door was opened on.
    Finally I would have been nice the bolt the controller down on the fender or firewall vs using a zip tie to fasten it to the factory wire harness. Kinda cheap looking to me. Once again for the cost of this kit I would have expected a bolt down controller.
    Overall I think these steps are awesome and my 3 complaints don't bother me at all. I would def buy these again if I were in the market for step. Take care and I hope this was helpful!
  10. Jul 2, 2013 at 8:01 AM
    #50
    chuongzzz
    chuongzzz Member
    Hi ppham444 , how can u get ur powerstep move up really fast when u close the door ? Mine I have to wait 5s for it ( I just installed yesterday ) , can u help me if u know why , thanks
  11. Jul 2, 2013 at 8:07 AM
    #51
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Jesus... 1300 dollars??? I would have to win the lottery to justify these.
  12. Jul 2, 2013 at 8:18 AM
    #52
    chuongzzz
    chuongzzz Member
    $1149 free shipping from electricstep.com
  13. Jul 2, 2013 at 11:48 AM
    #53
    ppham444
    Phuong
    Portland, OR
    Believe me, when you're as short as me, these are justified! lol Plus they look way cool.
  14. Jul 2, 2013 at 11:50 AM
    #54
    ppham444
    Phuong
    Portland, OR
    Chuongzzz, this should be the normal speed that it retracts. I'm not sure why it's taking yours so long. Did you splice the correct wire? I know there's a wire in there for your dome light that turns off after 5 seconds after you close the door. Check your wiring again.
  15. Jul 2, 2013 at 2:54 PM
    #55
    chuongzzz
    chuongzzz Member
    i called Amp tec and they said : it's take 2s delay for the new model so i think u got it long time ago , right ? anyway thanks u ppham444 and ... r u vietnamese (cause i'm vnese so just ask hi hi)
  16. Jul 2, 2013 at 4:05 PM
    #56
    ppham444
    Phuong
    Portland, OR
    I've had mine for about 2 years now. So I guess they changed the timing on these huh? Yeah, I'm Vietnamese. lol
  17. Aug 2, 2013 at 12:51 PM
    #57
    keninsb
    keninsb "Senior", Senior Member
    Ken
    Goleta, CA
    '13 Taco DC 4WD V6 LTD
    I had these on my '08 Tundra and they were awesome. I have also dealt directly with (driven to the company) their customer service and they can't be beat. They did change the shape of the step from previous models, I think that is why they are not as "stealth" as they used to be (mine were more of a "wedge" shape, more pointed outwardly, where the new ones are more rounded on both sides).
    Notice on my mount that the step itself is not centered on the mounts. This was the only way it looked even when the unit was retracted (up). As someone else mentioned, you just loosen some screws/nuts and slide the step into the desired position and then re-tighten.
    The LEDs that came with the kit were nice. They were fairly bright and were sealed and weatherproof. My only complaint about the kit was that the wiring could have been a little longer, both for the main module and the LEDs (the LEDs were a separate kit).
    As far as not having a switch, all you have to do is put the steps in the position that you want them (up/down) and then remove the fuse. That disables the steps and leaves them in position.
    I now have a 2013 Taco that I just lifted and am definitely getting these. AMP REALLY stands behind their stuff and makes a quality product.
    Ken
  18. Aug 2, 2013 at 1:04 PM
    #58
    TIM.TRDSparks
    TIM.TRDSparks Well-Known Member
    Myrtle Beach, SC
    08 Taco DCLB RR
    CBI BUSHMASTER, BUDBUILT SKIDS SET, OME SUSPENSION, DAKAR LEAFS, TRD EXHAUST AND CAI PLUS MORE
    These power steps are my favorite for trucks!
  19. Aug 2, 2013 at 3:56 PM
    #59
    keninsb
    Ken
    Goleta, CA
    Hey Tim, are you stalking me:p
  20. Aug 7, 2013 at 6:28 PM
    #60
    keninsb
    Ken
    Goleta, CA
    Can't believe it. I ordered a set of these babies yesterday afternoon from The PowerShop.com and they were delivered this morning and I installed them this afternoon! PCHearn is right, they are not nearly as discrete as I thought that they would be and definitely not as discrete as the pair on my Tundra. But I think what they sacrificed in stealth, they made up for in beefiness. They also improved the wiring harness to include the LEDs (those used to have to be routed and wired separately).
    My truck is kind of right in between where you definitely need steps/running boards and it would the "gee, those would be cool" area. I noticed that after lifting the truck my 9 year old was having a harder time getting in/out and I also noticed that I was "sliding" off the seat to get out instead of stepping out. I figured I would go ahead and get the steps now and save on the leather. Well, that's my excuse anyway:)
    Man, AMP make a QUALITY product. BTW, The Power Shop met ElectricStep.com's price and I avoided sales tax (Electric Step is in CA).
    Ken
