Amp problem
Discussion in 'Audio & Video' started by cole47, May 20, 2010.
  1. May 20, 2010 at 8:01 AM
    cole47
    cole47 [OP] Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    I am reinstalling a amp that i had in my truck for about 6 months, it has sat in my garage in a safe place for the past 2 or 3 months. My problem is when i hook everything up i get a red protect light on the amp. At first i thought it was a bad ground so i ran a ground wire and grounded it on the battery and the light was still on...im lost on things to troubleshoot, and ideas would be helpful
    Thanks
  2. May 20, 2010 at 8:16 AM
    DevL
    DevL Well-Known Member
    What kind of amp?
  3. May 20, 2010 at 10:17 AM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    Alpine PDX 1000
  4. May 20, 2010 at 11:03 AM
    orvis
    orvis Well-Known Member
    Winnipeg, Canada
    06 TRD off road
    I had more less the same problem with that amp, took it in and got a new one
  5. May 20, 2010 at 8:53 PM
    dolbytone
    dolbytone Well-Known Member
    09 TRD Off Road
    I think your amp is bad. Amps go into protect so they don't eat your speakers when they go kaput.
  6. May 21, 2010 at 7:06 AM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    figured as much...its still under warranty so ill take it back in
  7. May 21, 2010 at 7:09 AM
    xSpyderguyx
    xSpyderguyx Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    Yeah typically amps go into protect mode when one of the capacitors inside of them go fault or somtimes it can a be a bad ground (or not sufficieent power wire)
    Ive seen guys fry amps and wires because of wiring 8 guage power wire to a 2000 watt rms amp. haha
    Take her in man. GL with ur build;)
