amp question...
Discussion in 'Audio & Video' started by thebaker, Jan 17, 2013.
  1. Jan 17, 2013 at 9:33 PM
    thebaker
    thebaker [OP] Well-Known Member
    Byron
    NorCal
    2009 4x4 DC TRD Sport
    The only mod is a hole in my wallet!!!!!
    i'm currently running an alpine pdx-5 in my Tacoma. How hard would it be to add another amp to my set up? What would be needed? How many more wires would I have to run?
    Looking at the possibly of running two amp so I can run more power to the sub.
  2. Jan 18, 2013 at 10:59 AM
    96Taco
    96Taco Well-Known Member
    Alberta
    '04 V8 4Runner
    ..stay tuned
    Easy. Check the gauge of your power wire running your pdx-5. If it has enough capacity for the increased load your gold. If not you will probably have to run a thicker power wire.
    not sure why u want to add another amp tho..
  3. Jan 18, 2013 at 11:34 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    You can run a dist block too to split the power wire.
  4. Jan 18, 2013 at 3:56 PM
    chrispy
    chrispy Well-Known Member
    Winnipeg, Manitoba
    2012 Tacoma SR5 4X4
    Hi, would you mind posting pictures of your set up with the pdx-5? i'm currently looking into doing the same install
    Thanks
