Amp recommendations
Discussion in 'Audio & Video' started by rogerkamp8817, Nov 10, 2013.
  1. Nov 25, 2013 at 1:24 PM
    Aw9d
    Aw9d That one guy
    I do not suggest seat belt mounts. You ground should go into the frame. Get a JL Ground Plug and grommet and it will be 100% correct. Seat belt mounts do not attach to the frame.
  2. Nov 25, 2013 at 2:16 PM
    rogerkamp8817
    rogerkamp8817 [OP] Well-Known Member
    Orange County, California
    2010 Toyota TRD Off-Road 4x4, AC, Superwhite
    I actually found a bolt that is being used as a ground already, so i attached the amp's ground wire to that. It's close to the pre-cut opening in the carpet where the factory wires come out to plug into the seat (probably seat belt alarm and air bag plugs). You can see this bolt when you u-clip the carpet along the trim and lift up on it. I didn't sand at all. It seems to work fine.
  3. Nov 25, 2013 at 2:18 PM
    Aw9d
    Aw9d That one guy
    That doesn't sound like a very good ground location to be honest. Bad ground causes lots of issues. Good luck.
  4. Nov 25, 2013 at 2:25 PM
    rogerkamp8817
    I may sand it and possibly re-position it if i have issues, but I don't at this time.
    It's got a clip on it similar to the ground wire that attaches the negative terminal of the car's battery to the frame of the car. I think this bolt is designed intentionally as a ground by Toyota so that gives me some confidence.
  5. Nov 25, 2013 at 2:27 PM
    Aw9d
    Aw9d That one guy
    Remember, you are grounding an amp. Not a light, sensor or something that has little power draw.
    But what do I know, I've only been installing stereo's for 16+ years now. :anonymous:
  6. Nov 25, 2013 at 2:28 PM
    rogerkamp8817
    good point! this will be the first connection i check if any issues arise.
