Amp Setup Question?
Discussion in 'Audio & Video' started by flyby08, Sep 24, 2011.
  1. Sep 24, 2011 at 9:47 AM
    flyby08
    flyby08 [OP] Well-Known Member
    san francisco
    2008 TRD sport 4x4 short bed
    TRD Catback exhaust, Topdeck tonnaeu cover, locking gas cap, all weather floor mats, Pop-n-lock tailgate, painted black rims, volant CAI with RAM air scoop, 10" MTX thunder sub with 2ch amp, Alpine SPS-609 and 600, Pioneer AVHP-3200BT HU
    Hello everyone in TW land i was having a thought that I wanted to see if anyone could help me out with their part experiences.
    Currently in my taco I am running pioneer AVH -3200BT head unit with 4 Alpine type S speakers (6x9 in the front and 6-1/2" in the rear); and the speakers are running off of the head unit. I also have and 10" MTX sub running off a ch2 MTX amp that I have bridged at 280 RMS (this is a sub i had from a older subaru that i had)
    Now i have been thinking about amplifying the 4 four doors speakers as well; what my questions is would it be better to get a new 4ch amp for the speakers and have to 2 amps? or to replace the 2ch amp with a 5ch amp and run the whole system off one amp? I not sure the pros or cons from either setup any insight you guys would be able to provide would be much appreciated.
    thanks
    ps. please let me know if you need more info on the system that would help you answer the question.
  2. Sep 24, 2011 at 11:59 AM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    It will probably be cheaper to get another amp. The sound quality should be the same either way. Getting a 5-channel amp should result in a cleaner/simpler installation.
  3. Sep 24, 2011 at 2:54 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    ^^ agree'd
    i guess it depends if you want to spend more cash or not.
  4. Sep 24, 2011 at 2:56 PM
    loganlangley
    loganlangley Well-Known Member
    logan
    south alabama
    2011 trd sport 4x4
    Full JL Audio speaker swap with stealthbox, hid headlight and foglight conversion, weathertech floormats, UWS low profile black toolbox, 5100 billies with eibachs in the front and 5100 billies with 1.5 icon leaf pack in the rear.
    i have two amps in mine with a clean setup. mine sounds awesome.
  5. Sep 24, 2011 at 3:17 PM
    dolbytone
    dolbytone Well-Known Member
    09 TRD Off Road
    Careful to not buy a 4 channel amp that overpowers your 280 watts worth of sub. Of course, I'm not sure how well those Alpine door speakers hold up when you start pushing them with a little bit of sack either. Just be careful to get something that integrates well with what you already have.
    I personally went with a 5 channel amp, but that's ultimately less flexible in the event you wish to upgrade to biamping components or something later on.
  6. Sep 25, 2011 at 6:58 AM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    something like 75x4@ 4 ohm would work fine
    what i would do, personally, is buy something like 150x2 ditch the rear speakers and buy some nice components for up front
  7. Sep 25, 2011 at 8:07 AM
    Linelock4
    Linelock4 Member
    Jared
    New Hampshire
    04 Extra-cab V6 5-speed 4x4 Limited TRD
    Spectra intake and Air-Raid throttle body spacer.
    You can add an Alipine 4-channel V-power MRP-F300 to you SS series speakers and land the amp under your drivers front seat. I say this because I have done it for a customer I had. Just keep in mind there is a bracket under the seat that has a plug cliped to it. You are going to have to bend the bracket up out of the way. The reason is to allow the seat to move back and forth without getting hung up on the amp. I have used this exact amp with those exact speakers and as long as the cross overs are set right your good. Also you can just level make the gain on the amp to blend perfect with the sub.
  8. Sep 25, 2011 at 12:36 PM
    flyby08
    san francisco
    that is the actual setup that I was thinking about. I was just thinking that the two amps would be messy, but is sounds like it can be done cleanly. I am currently running a 8guage power cable from the battery, if i switch to the two amps would I need to upgrade to a 4 gauge to a distribution block?
    thanks for all the input everyone.
  9. Sep 25, 2011 at 12:45 PM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    8 might be small for both amps, id just do another run to the battery with 8 or 4
  10. Sep 25, 2011 at 2:11 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    Do this. If you run 2 amps, either will be fine.
    If you go to a 5 channel, still want to upgrade to a 4ga.
