Amp Under Drivers seat, tuning with the seat airbag unplugged?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rhallmcp, Apr 19, 2019.
  1. Apr 19, 2019 at 11:19 PM
    rhallmcp
    rhallmcp [OP] Well-Known Member
    Upstate NY
    2018 Trd Pro
    this may seem like a stupid question... But, i installed my amp under the seat in my truck, and am upgrading the head unit and need to re-tune everything. ill need to unplug the airbag in the seat, so im curious if there will be any issues starting everything up with the airbag unplugged.
  2. Apr 19, 2019 at 11:42 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    No, just the dash light will come on but will go off once you plug the airbag back in
  3. Apr 19, 2019 at 11:42 PM
    hawaii_dave
    hawaii_dave Well-Known Member
    2017 trd pro
    it should set a airbag code if you turn on the key with the airbag unplugged . you should be able to un bolt the seat but leave the wires plugged in . I have amps under both my front seats
  4. Apr 20, 2019 at 7:51 AM
    rhallmcp
    Upstate NY
    2018 Trd Pro
    ok, with moving the seat around i didnt want to set off the airbag... LOL
  5. Apr 20, 2019 at 7:54 AM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    Remove the negative battery cable first... that will ensure no inadvertent airbag deployment.
  6. Apr 20, 2019 at 4:35 PM
    rhallmcp
    Upstate NY
    2018 Trd Pro
    i was actually able to get all the new RCA cables run to the amp with the seat unbolted and leaned back, so it worked out pretty good. Had the battery cable unplugged to be safe.
