Amp under seat
Discussion in 'Audio & Video' started by Max_taco_noob181, Jul 27, 2023.
  1. Jul 27, 2023 at 8:11 AM
    Max_taco_noob181
    Max_taco_noob181 [OP] New Member
    Maximiliano
    2023 lunar rock tacoma trd off road
    Toyota
  2. Jul 27, 2023 at 8:32 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
  3. Jul 27, 2023 at 8:32 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Looks like a set of KS components. Any amp thats between 50 - 125 W RMS / channel should be good.
    Get a 5 channel if you plan on running a proper sub, get a key if you want to just drive moderate volumes and a powered underseat sub.
    Max_taco_noob181[OP] likes this.
  4. Jul 29, 2023 at 9:12 AM
    SuperAir
    SuperAir Well-Known Member
    Maine
    19 TRD ORAC Cement
    Eibach Stage 1, 17x8.5 Ray 10s, 265/70-17
    Key 500 for sub and key 200 for speaks is a good option and I had both neatly stowed under my drivers seat with no issues ( no power seats, mind you). I have since upgraded and am now running a 100x4 Alpine under the drivers seat and a 600x1 Alpine under passenger seat. No clearance issues on either one. Both are sitting on 1/4" ABS plates. Be sure to run a fuse at the battery and good high quality Oxygen free copper power and ground wires. I ran both of my Key amps off a single 8 gauge power wire from the battery to a junction block and it worked fine and was easy to run.. I upgraded to heavier wire when I upgraded amps.
    soundman98 likes this.
  5. Jul 30, 2023 at 11:41 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Them asking $500 for a set of kicker KS, some brackets, and harnesses makes me sick
    thebaker and soundman98 like this.
