Amp wiring to 1 ohm
Discussion in 'Audio & Video' started by Jpf8653, Nov 17, 2011.
  1. Nov 17, 2011 at 5:54 PM
    Jpf8653
    Jpf8653 [OP] Well-Known Member
    Justin
    Baton Rouge,LA
    Revtek 3" lift, Tinted Windows Wheels n' Tires Door Sill Protectors Rockford fosgate P3 shallow w/ alpine mono 500 amp in a MR MARV PORTED box Weathertech floor liner Rear TSB Pioneer 3200BT Double Din touch screen
    If u were to wire an amp to a 1 ohm load but it's not rated to run at 1 ohm. What will happen?
    No sound?
    Blown fuse?
    Will it work just may overheat?
  2. Nov 17, 2011 at 5:59 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    Hampton, VA
    '17 Tundra; '16 Odyssey; ;14 A4
  3. Nov 17, 2011 at 6:00 PM
    Jpf8653
    Justin
    Baton Rouge,LA
    Nice. Really though?
    My alpine is rated for 2 ohms but not 1.
  4. Nov 17, 2011 at 7:04 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    Generally, they have a protection circuit in place, and it will shut the amp down before damage occurs.
  5. Nov 18, 2011 at 3:41 AM
    Slimwood Shady
    Linwood
    Hampton, VA
    This^^^^ Usually when you try to turn it up and give thespeakers some juice the amp will go into protection mode. The worst case scenariois you could blow your amp and your subs...and possibly the pre amps on yourhead unit...:rolleyes:
  6. Nov 18, 2011 at 9:02 AM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '06 DC LB 4x4
    OME lift w/ Dakars & 885's Remote Start w/ window control
    I think blowing the pre-amps on the headunit would be pretty unlikely... you'd have to get some major feedback from the amp going into the headunit to do that. I guess it could happen but I'm pretty doubtful - unless the amp is a real POS
  7. Nov 18, 2011 at 8:28 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    On an alpine it's not worth trying, alpine amps aren't exactly the most stable thing at a low impedance, is it going to damage anything? Probably not, it will just get up and shut off all the time. Really annoying. Jl zapco and Rockford are all very stable if you need something that can handle a 1 ohm load
