Amp with stock HU... BIG PROBLEM
Discussion in 'Audio & Video' started by brannoz91, May 13, 2008.
  1. May 13, 2008 at 7:24 PM
    brannoz91
    brannoz91 [OP] New Member
    GB
    02 Prerunner dbl cab
    Flowmaster exhaust
    I put in an amplifier with my stock headunit using a line-level converter. It worked perfectly fine for nearly a month and then I decided to remove the subwoofer for a day to get more room in my backseat. I did not know to disconnect my amp and after about 2 hours of radio use, my stereo would not play anything at all:confused: I think think it might have sent power back through my stereo and fried it.
    Does anybody have an explanation for what the problem might be?
  2. May 13, 2008 at 7:59 PM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    Loose wire maybe? How did you connect the line-level converter? Maybe loosened something up?
  3. May 13, 2008 at 8:01 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    did u isolated the disconnected sub wires??? maybe they touch each other and created a short thats my guess....
  4. May 13, 2008 at 8:03 PM
    brannoz91
    GB
    Flowmaster exhaust
    I isolated the wires and everthing was fine. But i have no output or anything coming from my stereo, even with my amp disconnected:confused:
  5. May 13, 2008 at 8:04 PM
    eordonez
    Ed
    Chihuahua, Mexico
    could it be something like the balance and fade of the stereo?? that you accidentally mess that up??
  6. May 14, 2008 at 7:25 AM
    GotLift37
    North East AL
    07 4Runner 4WD
    Say if you try to turn the volume up or down. Or mess with the bass, treb, fade and bal controls, does anything even come up that says the volume is going up or down?
  7. May 14, 2008 at 8:45 AM
    ShorelineFab
    ShorelineFab Ask for forgiveness than permission
    The O.C, CA
    2008 DBL CAB, BLACK, TRD SPORT, TSB/SUP/UPGRA
    Maybe it's time for a new radio! ;)
  8. May 14, 2008 at 8:50 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    checked the fuses yet?
  9. May 14, 2008 at 3:53 PM
    brannoz91
    GB
    Flowmaster exhaust
    I checked every fuse I could find and they are all good. It shows that the song is playing and I dont have a volume gage but i can turn it all the way up... I cant figure it out.
  10. May 14, 2008 at 5:50 PM
    GotLift37
    North East AL
    07 4Runner 4WD
    You have the JBL system? If so. Hook the factory amp back up. Will fix your problems. But if not, wouldnt have a clue
  11. May 14, 2008 at 8:01 PM
    brannoz91
    GB
    Flowmaster exhaust
    thank you very much. I will try that and if that doesnt work Ill seek professional help
  12. May 14, 2008 at 9:12 PM
    GotLift37
    North East AL
    07 4Runner 4WD
    If you have the factory JBL system, I know you dont have the amp hooked up :D Same thing happened to me lol. But hook the factory sub back up also other wise the HU and speakers will cut in and out once in a while.
