Amplifier on oem stereo 2008
Discussion in 'Audio & Video' started by bra, May 6, 2018.
  1. May 6, 2018 at 1:08 PM
    bra
    bra [OP] Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
    Hi,
    Is there a way to mount an amplifier on a 2008 stereo? I'd like to keep it stock and just add a subwoofer
  2. May 6, 2018 at 1:20 PM
    FourBanger99
    FourBanger99 4 Banger Taco
    Bayne
    Birmingham
    2012 Black Tacoma 2.7 AC SR5 4x4
    Full OME Suspension CB Diff Breather Duratracs
    Curious. I’d like to do the same
    bra[OP] likes this.
  3. May 6, 2018 at 8:39 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    Yes, Just google "Adding amp to stock headunit".
    bra[OP] likes this.
  4. May 6, 2018 at 8:48 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    What he said. In short you'll need to tap into the speaker wires behind the headunit or somewhere before the doors, add a converter that changes the output of the speaker wire into RCA outputs, and then you have a source for your sub amp.
    All that being said I wouldn't do it, I'd swap to an aftermarket headunit. A lot of those converters, even the expensive ones, are hit or miss and it sucks doing all that work just to have a weird hum or delay in your sub. If you use an aftermarket headunit, which only takes a couple of hours to swap in, you'll have at least one dedicated sub out and likely built in controls to help adjust/tune the output to the amp as well as the manual controls on amp. That way you can tinker with the sub until your happy.
    bra[OP] likes this.
  5. May 7, 2018 at 1:11 PM
    bra
    Badges off
    Thanks for your reply, in fact I'd like to add the JBL Bassprosl which is a pre amplified subwoofer
    So bad for the headunit I like the oem ones especially because of the steering wheel controls
  6. May 7, 2018 at 2:11 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    All good man, just trying to help you out.
    It's really easy to keep the steering wheel controls with an aftermarket head unit. You just tap in a little module, I use the Axxess version, and you keep all your steering wheel controls. I've had to many bad experiences trying to match up aftermarket equipment to stock head units to recommend doing that.
    bra[QUOTED][OP] likes this.
