Amplifier Wire Terminals
Discussion in 'Audio & Video' started by nammer, Oct 24, 2013.
  1. Oct 24, 2013 at 10:22 PM
    nammer
    nammer [OP] Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    Hi all, I was wondering are there any terminals that can be used for these types of amps? or are you just supposed to squeeze the wire in there? thanks
    I'm more concerned about the power and ground wires
    Thanks
  2. Oct 24, 2013 at 10:26 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Strip the insulation from the end of the wire and tin it with solder.
    Crank the screws down, then check torque after a few weeks.
  3. Oct 24, 2013 at 10:32 PM
    nammer
    Nam
    Bradenton, Florida
    sweet, that's awesome advice, thanks rich, I might do that, but do terminals even exist for that type of connection
  4. Oct 24, 2013 at 10:37 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I've never seen them for cables that large.
    The power interface module for my traffic signal battery backups have a terminal crimped onto the #10 wires.
    It's like a butt-splice crimp connector, but the non-insulated part is more of a pin.
    But on a large amplifier feed, it's just introducing one more unsoldered failure point.
    http://www.cable-jointing.com/produ...-stalk-cable-connectors-crimp-terminals-mta-c
  5. Oct 24, 2013 at 10:39 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Looks like they are available for some pretty large conductors, but the secondary problem is that you can't use a basic hardware store crimp tool on anything much larger than #8 or #10.
    The crimp tool for #4 looks like a pair of bolt cutters (and I have seen some DIY tools made from bolt cutters).
  6. Oct 24, 2013 at 10:56 PM
    nammer
    Nam
    Bradenton, Florida
    i guess if it's not typically done, then there is no need for me to do it, I'll most likely go the solder route, thanks for your help!
  7. Oct 25, 2013 at 6:03 AM
    ike3000
    ike3000 Well-Known Member
    to echo what Rich said, you really don't need a pin connector for this type of application. i've installed many amps that use the same connections and have had zero issues cranking down the screw on bare wire. also when you screw onto bare wire it will deform and become "flat" giving the wire more surface area contact with the amp terminal. more contact surface area equates to more current transfer. pins are pretty hard metal and will typically stay a rigid barrel.
    my only word of caution is not go to town tightening the screw onto bare wire. over tightening the screw can compress wire strands to the point that they will break. that's where it's a good idea to solder.
    GL!
  8. Oct 25, 2013 at 6:12 AM
    pcabinatan
    pcabinatan Well-Known Member
    Avondale, Arizona
    K&N Intake, 35w 6K HID's, Plastidip badges
    They do sell terminals that will "crimp" onto a 4ga wire. check out Stinger Electronics. They do alot of car audio accessories
  9. Oct 25, 2013 at 7:10 AM
    nammer
    Nam
    Bradenton, Florida
    cool thanks, I actually tried it last night, and it's a really solid connection
    yea the amp kit actually came with some, but they were just the fork or ring kind, I was just wondering if they made any specifically for that screw down terminal
    or is this it?
    http://stingerelectronics.com/productDetails.aspx?ProductId=447&CategoryID=10
    damn that's almost as much as my amp wiring kit :eek:
  10. Oct 25, 2013 at 4:35 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    They sell terminals that will crimp onto 0000.
    But you are not going to be able to PROPERLY crimp anything larger than 8-10ga using typical hardware store/auto parts store tools.
    6ga and heavier require a heavier tool:
    http://www.kleintools.com/catalog/crimpingcutting-tools/large-crimp-tool-compound-action
    For wire in the #2-#6 range, you can get by with a pair of bolt cutters with the cutting edges ground flat and a hole drilled through the edges of the blades to shape the lug.
  11. Oct 25, 2013 at 4:39 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
  12. Oct 25, 2013 at 4:55 PM
    nammer
    Nam
    Bradenton, Florida
    :eek: oh true, yea it's the same
