Amplifiers: Kenwood vs Pioneer
Discussion in 'Audio & Video' started by y2kh8r, Apr 29, 2016.
Who makes the better amplifier for sound quality?
Poll closed May 13, 2016.
  1. Kenwood
    100.0%
  2. Pioneer
    0 vote(s)
    0.0%
  1. Apr 29, 2016 at 5:32 PM
    y2kh8r
    y2kh8r [OP] Member
    01 tacoma 2.4 5-speed
    Specifically, I'm looking at Pioneer GM-A6604 vs Kenwood KAC-8406. The Kenwood has 10 more WPC RMS, but the Pioneer has half the THD with 0.05% distortion. The Price difference isn't a deciding factor for me here, but the Kenwood is $30 more. I'm more concerned about sound quality than power.
    edit: clarification.
  2. Apr 29, 2016 at 5:35 PM
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    Neither... You can do much better (IF price isn't a factor)
  3. Apr 29, 2016 at 5:35 PM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    If it has to be between those two, Kenwood for sure.
  4. Apr 29, 2016 at 5:37 PM
    horstuff
    horstuff Re-member
    PNW
    Agreed... Neither of those companies are known for their amps. Head units are their bread and butter.
  5. Apr 29, 2016 at 5:49 PM
    y2kh8r
    y2kh8r [OP] Member
    Price is definitely a factor, though I'm willing to spend just a little more than these are selling for. My max is about $150.
  6. Apr 29, 2016 at 5:52 PM
    Do58
    I was just quoting your op. I didn't know if you meant price not a factor in general or between these 2 amps you were referring to. Good luck
  7. Apr 29, 2016 at 6:29 PM
    y2kh8r
    y2kh8r [OP] Member
    Sorry about that- I should have been a little more clear, I meant the price difference between the two amps wasn't a deciding factor.
  8. Apr 30, 2016 at 4:29 AM
    Rus TRD
    Rus TRD Well-Known Member
    Don
    Pa.
    2015 DC TRD Sport
    Bilstein 5100 with 884 Springs. Full audio system. Stealth 6 Wheels. Cali led light.
    If you are going to run a 5 channel amp I have the Kenwood excelon 900 amp in my car. This amp kicks ass. Sounds good. Maybe this will help.
  9. Apr 30, 2016 at 5:03 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Both amps are factory rated at ≤1%THD+N (and I'd be surprised if you could tell the difference in .05% and .1% THD in the intended environment). The Kenwood has a higher S/N ratio (100 to 95) and can make more power. If I
    HAD to choose between these 2 amps and no others I'd choose the Kenwood simply because it can make more power and has a better S/N ratio. The crossovers on the Pioneer are a little more flexible if that's an issue.
    Nothing fancy going on here, but they both probably sound pretty nice. I think the Kenwood looks better - Not that that matters.
  10. Apr 30, 2016 at 5:41 AM
    y2kh8r
    y2kh8r [OP] Member
    Your vote for the Kenwood is maybe the third or fourth so far (I'm asking in another community as well).
    I dug deeper after posting here, and noticed that the manufacturer's sites don't give specific THD below %.1%. The specs I had were from sonicelectronix. I don't know where they pulled their specs from, but it didn't come from the manufacturer's websites. Apparently, THD is a level playing field based on manufacturer's info, which makes the choice between these two particular amps pretty easy.
  11. Apr 30, 2016 at 6:03 AM
    Rus TRD
    Don
    Pa.
    2015 DC TRD Sport
    Here is another thought. I have always been a Rockford Fosgate fan. This is just my opinion. Three years ago when my installer put my audio install into my other car I was going all Rockford because my speakers and sub is all Rockford but their new line was on back order so I had another friend recommend this Kenwood amp. After my installer put this amp in the car he told me if I wanted to change it out when the Rockford came a avilable he would switch it out. I kept it in the car because it is thin and small and sounds great. Now I'm working on my next install for my truck.
  12. Apr 30, 2016 at 6:14 AM
    CaptainReverso
    CaptainReverso Well-Known Member
    Cory
    Gardena
    2015 TRD off road 4x4 DBL cab Magnetic Grey
    Off Road Stuff
    Alpine. If your not looking to spend a fortune, best bang for your buck IMO
  13. Apr 30, 2016 at 12:53 PM
    SlowComa666
    SlowComa666 Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
    when not driven to distortion there should be no real audible difference between level matched amplifiers
    the distortion numbers you guys list are completely inaudible and your belief of what is audible distortion might be wrong.
    everyone likes numbers in their specifications for products. we've all been conditioned that we want some numbers bigger and others smaller, but what do those numbers actually sound like?
    distortion is one of those numbers that can be deceiving. manufacturers are going to tune their tests to give the best specification number possible.
    this entire seminar was great but i skipped to the part about distortion
    https://youtu.be/2V6YN-mshmY?t=1348
  14. May 1, 2016 at 6:26 AM
    Marine 8541
    Marine 8541 Well-Known Member
    Jimmy
    Iowa
    Tacoma SR5 4x4
    Stock
    I just put a kenwood five channel on my kids ride pushing a P3 12 with kicker door speakers. Sounds great for a $185 amp
