Amps: 5 channel vs 4ch+Mono, plus mounting advice
Discussion in 'Audio & Video' started by skierd, May 17, 2018.
  1. May 17, 2018 at 6:49 PM
    skierd
    skierd [OP] Well-Known Member
    David
    Fairbanks, AK
    2017 SR DCSB
    I’m planning out audio upgrades for my 2017 SR DC as the stock system is underwhelming to say the least. Functionally, and assuming same to similar rms output, is there much difference between going with a 5 channel amp vs a 4ch and a mono amp for sub(s)? Specifically I’m thinking a Kicker cx600.5 or an alpine power pack and a 300w mono amp (haven’t figured that part yet).
    I’m definitely adding a subwoofer behind the rear passenger bench, ive got two kids in car seats so I’d much rather take the space i can’t get to vs the drivers side. Planning for no more than 300w rms. I’m 90% sure I’m doing the kicker tweeters and maybe the door speakers if I don’t think the tweets and a sub alone does enough.
    I’d also really like to mount the amp in the bin under the rear bench on the passenger side. Any thoughts on that location?
  2. May 17, 2018 at 10:27 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    I would go with a 5ch for what you're trying to accomplish, fair less complicated and cost effective than running 2 amps.
  3. May 18, 2018 at 5:51 AM
    Gekicker08
    Gekicker08 Finally in a Tacoma
    Dylan
    Charleston, SC
    2016 DC TRD OR 4x4 Inferno
    The taco tunes 5 channel amp and their subwoofer setup is awesome. It is about 2 hours of an install and you'll be golden. Its also not that difficult on the wallet.
  4. May 18, 2018 at 6:08 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    It's really a trade-off, depends on what is important to you.
    - easier to install a single amp
    - easier to upgrade one or the other with 2, as your needs/desires change
    I've done both ways and am good right now with a single 4+1 for the simplicity, but if I tended to change/upgrade more often, my mind could easily change to the other.
  5. May 18, 2018 at 10:34 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    If you are trying to save space then go with a single amp. But 5 channel amps can be a bit on the larger side...
    If you want you would get some low rms high sensitivity speakers and power them with an alpine powerpack, and then you could get the new audio control LCM to power a sub. Both are really small and can be tucked away easily. The LCM can probably be mounted to the top of the box.
    https://www.youtube.com/watch?v=Vb6L4ky56vw&list=PLgpoOVEheqIxaaBIsUHTldVpEeNVYF6NE&index=70&t=0s
    https://www.youtube.com/watch?v=2dCXRGp-nEc
  6. May 18, 2018 at 12:14 PM
    outxider
    outxider Never stop exploring.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Same here. Used to run the alpine powerpack tucked above the glove box and a mono amp for the sub behind the rear cubby. Switched it out to a 5ch in the same location for simplicity and more power to the speakers.
  7. May 18, 2018 at 7:38 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    '11 TRD Off Road
    For 500w rms or less on the sub output, there is no need for multiple amps these days. Search around (i'm not supporting buy-n-large by providing 'them' a direct link) and find an Alpine PDX V9 on sale if you want a really nice, great looking amp that doesn't need a lot of current. The sound is completely perfect, and its all on your speakers with these PDX's. You can always turn keep the gain lower if you don't need all the power. Mount it under the seat and be done with it.
    Derek Big D Wiz also tested and was ok with the Pioneer GM-D9605 and Kenwood X801-5 - these are a little less costly, have good output and sound good.
    Another youtuber I found also tested the latest Infinity Kappa series amp with an amp dyno- it did slightly more than its rating. I ran Infinity Kappa amps back in the day and was really happy (I should have never sold the 202a and 54a)- they're also easier on the wallet. Infinity Kappa k5 is $300 at Crutchfield, and is right at the power range you want.
    outxider, Purpleman and skierd [OP] like this.
  8. May 20, 2018 at 7:07 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Lynnwood wa.
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm going with a full set up soon too. Taco tunes makes it a no brainer for me. I've wired dozens of systems and the simplicity/ quality balance seems best for my needs.
