Amsoil ATF in transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tmuhler, Jun 27, 2019.
  1. Oct 9, 2022 at 4:27 PM
    Bishop84
    Bishop84 Well-Known Member
    Where did you read that? It replaced T-IV in 2005 which was also synthetic.
  2. Oct 9, 2022 at 8:23 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    toyota ws fluid is semi-synthetic
  3. Oct 9, 2022 at 8:45 PM
    Bishop84
    No, it has some minerals, but its definitely a synthetic. There is no literature that supports your claim.
  4. Oct 10, 2022 at 8:26 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    every source i've found says that WS is only a semi-synthetic. that's why a lot of people use the Idemitsu fluid because it's a full syn.
    just did my first drain and fill after 14k miles and it was dark brown. really like the idemitsu stuff.
    https://www.idemitsulubricants.com/product/atf-type-tls-lv
  5. Mar 17, 2023 at 5:58 PM
    kbecerra
    kbecerra Well-Known Member
    2006 Red Tacoma Double Cab Long Bed PreRunner
    Eibach Pro-Truck Lift (Stage 1), Deaver AAL, JBA STD UCAs
    Just ordered 5 quarts of AMSOil Signature Series along with OEM transmission gasket, filter l, & two washers.
    I know that my 2006 Tacoma Prerunner with (168,000 miles) was last serviced at the Dealership and will have the Toyota Genuine WS in it.
    Im planing to do a Drain & Fill with the same AMSOil (approx 3qts) three more times in 1 week intervals to ultimate have close to all AMSOil.
    The reason I’m doing it this way is because I was told that a complete flush can potentially be harmful since the metallic particles of the gears can be flushed into areas that the should be in the first as opposed to downward to the pan.
    Can any confirm they have done this?
  6. Mar 18, 2023 at 8:53 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    When I switched to Amsoil I dropped the pan and replaced the trans filter (220k miles), then used the trans cooler lines (after the intercooler) to pull a quart at a time, replacing a quart at a time of Amsoil into the fill port. When Amsoil came out of the far side of the coolant line I topped off the fill port to make sure I had a full quart additional over the total removed so I could drain to final full volume.
    35 or 45k miles previously I had done a full change (using the trans cooler lines) with Toyota WS, so I knew it was full (or full enough), and the total removed during the filter/amsoil change was very close to the specified capacity of the trans. I'm not concerned about the small amount of WS that is mixed in.
