AMSOIL engine flush 3rd gen good or bad.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thekingd93, Feb 27, 2023.
  1. Feb 27, 2023 at 1:25 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I would just change more often. I still wouldn't flush. But that's my opinion on it. Whatever that is worth.
  2. Feb 27, 2023 at 3:39 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    NEVER flush an engine it's just asking for trouble ......and if there's sludge it's too late.
  3. Feb 27, 2023 at 3:57 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    This engine doesn’t need a flush
    Just change the oil every 5 k with a Toyota filter and quality oil.
    It will stay very clean inside
    Paul kersey likes this.
  4. Feb 27, 2023 at 5:46 PM
    Thekingd93
    Thekingd93 [OP] Active Member
    David
    2020 Tacoma SR5 V6
    It does not have a dip stick to check the fluid level like the good old days
  5. Feb 27, 2023 at 5:49 PM
    Thekingd93
    David
    2020 Tacoma SR5 V6
    Trying to avoid problems down the road and potentially get 300,000 miles out of it with simple and inexpensive DIY maintenance
  6. Feb 27, 2023 at 5:51 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    correct we dont have a dip stick for the trans but its serviceable.
  7. Feb 27, 2023 at 6:40 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    May want to skip the flush then. It does nothing to help a near new engine that was serviced. Flushes are for neglected vehicles that someone decided to run for 30k miles between oil changes
  8. Feb 27, 2023 at 7:10 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Because it's pressurized... To keep bad things out.
  9. Feb 27, 2023 at 8:56 PM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    Just curious what specific proof you’ve seen
    hiPSI and shakerhood like this.
  10. Feb 28, 2023 at 1:05 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Yah I’m with you. For me it’s a last resort. I’m going to do 2-3 back to back changes on very short intervals with some lower cost oil to help flush it out and then replace with new Amsoil Signature. I’ve only used OEM filters ever so will likely do the same and change with each. No sludge issues either when I had the valve covers off doing cam gears a couple years ago.
  11. Feb 28, 2023 at 2:11 AM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    A complete waste of money.
    nudavinci64 likes this.
  12. Feb 28, 2023 at 4:09 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I agree, why are so many concerned so much about oil? Just about any synthetic that meets the manufactures specs. are good to use. You'd think a taste test was being done.
    hiPSI and BillyE like this.
  13. Feb 28, 2023 at 4:43 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    Feels like alot of unnecessary time and money. glad neither are mine.
    shakerhood and zoo truck like this.
  14. Feb 28, 2023 at 4:50 AM
    Paul kersey
    Paul kersey Member
    Demitsu 0w20 gf-6 is the original Toyota oil befor Exxon Mobile never will need a flush if used properly
  15. Feb 28, 2023 at 5:04 AM
    #35
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    The "sludge" paranoia in this thread is so thick, you could cut it with a knife. It'll be OK, i promise. :sawzall:
    hiPSI likes this.
  16. Feb 28, 2023 at 5:16 AM
    #36
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    If you have your transmission flushed you won't have to wait until 300k for the end of inexpensive maintenance.
  17. Feb 28, 2023 at 8:18 PM
    #37
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Im wondering too.
    hiPSI likes this.
  18. Mar 1, 2023 at 5:26 AM
    #38
    zoo truck
    None
    Only advantage we saw royal purple accomplish was on a buddies engine dyno that he uses for his 358 cu. in. nascar engines was a slight increase in hp over all the oils he's tested.
