Amsoil filter?
Discussion in '4 Cylinder' started by Reaper22, Feb 19, 2010.
  1. Feb 19, 2010 at 5:41 PM
    Reaper22
    Reaper22 [OP] Well-Known Member
    Palmyra Missouri
    SR5 Tacoma
    Radient Red, Red Grille, Debadge'd, Blacken'd Headlights, DTRL's, Cruise Control, Fog Lights, 2 1\2" suspension lift, 285\75\16 Nitto Dune Grapplers, Pioneer Premier DEH-P510UB stereo, Pioneer 3 way fronts with factory tweeters & Kenwood tweeters, Kenwood truck boxes behide seats with 8" subs in each, Wet suit like tacoma seat covers
    Does anyone have a number on the amsoil oil filter for the 2.7, I am going to get the 0w30 oil and my dealer said he called his tech guy and they were discontinued. Also mabe a number for the air filter as well....
    Thanks..
  2. Feb 19, 2010 at 5:45 PM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    Sorry I cant answer your question but my friend just became a amsoil dealer. He signed up online and gets it cheaper now. Is amsoil as good as every one says its suppose to be or should i just stick to mobil 1. Sorry if i thread jacked.
  3. Feb 19, 2010 at 6:00 PM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    Not really sure, I have mobile 1 in it now but I like the fact that the 0w30 you can get 25000 or once a year out of an oil change..
    BTW Nice looking white truck ya have there..
  4. Feb 19, 2010 at 6:07 PM
    MikeyD
    Sayreville NJ
    Thanks same to you. Yours was lifted before mine was and i always drooled over it.
  5. Feb 19, 2010 at 8:03 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
  6. Feb 19, 2010 at 8:22 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    AMSoil stopped selling their Ea oil filter for toyota, lexus, and some pontiac engines due to them causing the oil pressure light to come on. They sell the MANN filters as alternatives, but they have to be changed every 7500 mi.
  7. Feb 20, 2010 at 2:47 AM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    Thanks man, That's what my dealer was telling me but wanted to be sure..
    Is there a filter that will last further than that?
  8. Feb 20, 2010 at 7:11 AM
    afd23a
    The Dynamo of Dixie
    Not that AMSoil sells, unless you go for a bypass system.
  9. Feb 20, 2010 at 7:29 AM
    sweater914
    sweater914 Well-Known Member
    North Dakota
    '09 I4 5spd Access Cab Timberland Mica SR5
    The Amsoil filter for the 4-banger is the EaO57. Amsoil no longer recommends this filter due to the oil pressure/sludge issue stated above. You now have to change the alternative filter at the OEM recommended intervals, I believe it's 5000 miles. The crankcase oil will still be good for 25000/35000 miles depending on which oil you choose, you just have to change the filter more often.
    I will continue to use the EaO filter because my wife doesn't put many miles on the truck and change the filter twice a year, like the old filters.
  10. Mar 8, 2010 at 9:07 PM
    B_brand
    B_brand Well-Known Member
    Brandon
    Oklahoma
    I would not buy an Amsoil filter for a Toyota. One starved my engine for oil and ruined it.
  11. Mar 9, 2010 at 9:35 AM
    afd23a
    The Dynamo of Dixie
    Unfortunately, that's why Amsoil doesn't spec them anymore and recommend the MANN filters for certain Toyotas. Found a link to the TSB they issued last year. http://www.sinwal.com/data/TSB_FL-2009-05-01_Toyota1.pdf
