Amsoil for engine oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sabre170, Apr 1, 2018.
  1. Apr 1, 2018 at 10:49 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Amsoil is really good but it's expensive, I personally run Castrol and love it. I've never been a fan of Mobil 1 due to some testing I've seen. YMMV
  2. Apr 1, 2018 at 10:51 AM
    Fortunt1
    Fortunt1 Well-Known Member
    Thomas
    Iowa
    16' SRT Charger...purple
    This guy was an engineer and knew a lot about modern oils, always hypothesized that it would make it that far but knew nobody would believe him so he did it himself. Said he seen the vehicle years later at well over 200k and it ran well and had 0 issues other than standard maintenance items
  3. Apr 1, 2018 at 10:53 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    AMSOIL for me! (Just stick to the correct weight)
  4. Apr 1, 2018 at 10:56 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    That’s funny reminds me of my brother’s old Dodge truck. He never changed the oil because it leaked so much and he had to always top it off.
    He would pull into the full service stations and say, “fill it up, and check the gas, too.”
  5. Apr 1, 2018 at 11:19 AM
    Orangecrush
    Orangecrush Well-Known Member
    Rob
    Abq NM
    17 OFFROAD Taco SB
    Mobil 1
    Goes on sale at Costco every so often and so it’s cheeeeeeap!
    I Love COSTCO!
    Vlady, TRD493 and Fortunt1 like this.
  6. Apr 1, 2018 at 11:26 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  7. Apr 1, 2018 at 11:33 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Plus $12 rebates thru Mobil making it a great deal.
    Orangecrush[QUOTED] likes this.
  8. Apr 1, 2018 at 11:41 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    If Mobil 1 is good enough as factory fill on Corvettes, Porsches, and Mercedes, it’s good enough for Tacomas. JMO.
    Kev250R, FLYH2O, kimo and 3 others like this.
  9. Apr 1, 2018 at 11:48 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  10. Apr 1, 2018 at 11:50 AM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Well not quite. Oil sitting in a bottle on the shelf has not been exposed to the conditions of a running engine. Once you run the engine (and keep in mind there are still the dregs of the old oil sitting in the sump because you simply can't drain it bone dry) you stir in a lot of extra contaminants that start a degradation process that is self-sustaining and increases with time, breaking down additives and increasing overall acidity which breaks down even more additives (and further increases acidity). Let that process sit in an oil pan, and it's gonna start degrading.
    Does it matter to the point of changing every year? Probably not, but it does matter.
    My guess is that with modern oils, 1 year is indeed a gross over-estimation of the speed of the process. I'd wager something like 2-3 or more years, so for all intents and purposes changing for miles not years is perfectly acceptable for all but the most neglected of autos.
    That said, overdoing your OCI can't hurt an engine.:notsure:
  11. Apr 1, 2018 at 12:50 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Dealer OW20. Just had mine done for 42.00.
    G.
  12. Apr 1, 2018 at 1:17 PM
    Husky Driver
    Husky Driver Kyna's chauffeur
    Kipp
    40°35'09.0"N 105°04'38.3"W
    2k T4R3 SR5 (Sport Edition Highlander SX) TRD
    Toytec Ultimate 3" lift susp w/ OME 891 rear coils, Bilstein 5100 shocks front & 5125 rear, ARB 'Roo Bar, Warn VR10k, 0.7, 2 & 11-meter 2 way radios FCC Lic KE0TDD, Nitrogen inflated 33" BFGoodrich All-Terrain T/A KO2s, FlexFuel E-85 conversion, AFe lifetime filter, Savage Offroad rock sliders, Ryno All Terrain 4.5mm skid plates, Line-X coatings on the armor, LifetimeLED & Rigid Industries LED headlights, UltraGauge 1.2, T3q 4.10 eLocker with armor from LROR, AmsOil lubricants used throughout. CBI plate rear bumper with swingaway, SPC Light Racing UCAs, ARB SS170HF Safari snorkel w/ Afrikaans centrifugal pre-cleaner, Tacoma antenna mod, TRD Supercharger w/ URD 7th inj. & URD pulleys, Anti-Dark engine bay lighting system. Having gone 250k, Aug 2016 was the time to replace the original clutch & get the driver's seat rebuilt/stuffed. Front & back Weathertech liners. '05 Tundra front disc brake swap. Full length Rocky Mountain Rack with 40" lightbar, Alternating strobe rear dust lights. I used a warm weekend in March 2022 to finally install my brand new from old stock 2000 4Runner driver's seat. $800 directly from the factory in Sapporo, Hokkaido, Japan.
    I've been using AmsOil for 20 years now. As it was said before, use mineral sourced oil for the break in & then I use spec 5w-30 AmsOil XL (12k max mileage) for my 5VZ-FE. At $9.15 a qt., it's actually $1 less than Castrol high mileage. I put one of those Fumoto Engine Oil Valves in the pan & it has made for the fastest, cleanest oil changes ever. Get the engine up to operating temp (195F), then drain completely & not get burned. I also run E-85 so there's no carbon in the oil, since EOTH burns completely without soot. Just over 1/4 of a million miles & still going strong. I had my emissions tested last week & found out that my emissions actually went down considerably compared to the test I had done 2 yrs ago before the TRD/Magnuson supercharger install.
    pir897 likes this.
  13. Apr 1, 2018 at 1:40 PM
    taco woodeye
    taco woodeye Well-Known Member
    san jose CA
    2018 SR 4x2 Utility Delete Midnight Black Metallic.
    High Temperature High Shear (HTHS)
    measures the thickness of motor oil.
    HTHS. 0W20
    TGMO 2.60 immediately shears to ~2.45.
    AMSOIL 2.67.
    M1 2.7
    RedLine 2.9.
    Also consider motor oil design.
    I do not like TGMO because
    of the usage of high dosage viscosity index improvers.
    I say this contributes to oil consumption.
    My choice is Pennzoil Gold Synthetic Blend 0W20
    with OCI of 7.5k miles and FCI of 15K miles.
    $4/qt at Walmart.
    BTW As a delivery driver subcontractor,
    I have used a variety of very thin motor oils,
    for hundreds of thousands of miles,
    going back 6 years,
    and my comments are as,
    merely a consumer,
    but one with lots of experience.
    Sustina 0W20.
    TGMO 0W20.
    MGMO 0W20.
    Ravenol 0W16.
    Citgo 0W16.
    BillsSR5 likes this.
  14. Apr 1, 2018 at 1:49 PM
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    I'll add my personal experience with Amsoil engine oil.
    I used Amsoil in my 2001 Dodge Cummins from day one (purchased the truck brand new). I sold the truck in 2015 to a guy who is a professional diesel mechanic. He took the head off to some work to it, and he showed me you could still see the original factory hone marks in the cylinder walls. Engine had 150K miles on it, I towed a good bit with the truck, so the engine was well used and worked fairly hard at times. That convinced me of the quality of Amsoil products, and I intend to continue using their products in my Taco.
    I'm not a brand fanatic, nor am I an Amsoil distributor, just a very satisfied customer. I also used Blackstone oil analysis in every oil change with the Cummins, and at 10K mile oil & filter changes, the Cummins oil reports were always excellent. I have no experience with any other oil/filters, so I am not able to make any comparisons.
    I'm very happy with Amsoil, but I won't make any claims that there may not be superior products out there.
    NAAC3TACO and Husky Driver like this.
  15. Apr 1, 2018 at 2:02 PM
    #35
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    kimo likes this.
  16. Apr 1, 2018 at 2:04 PM
    #36
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    I'm a Gastrol guy. Owned 4 Tacoma's and will only put Gastrol in my Taco's.
    Vlady and FFBlack like this.
  17. Apr 1, 2018 at 3:15 PM
    #37
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    I always kept a spare can of Castrol 20/50 oil in my old 1966 model year coupe while daily driving it from 1978 to 1986.
    I removed this can from the trunk wheel well when I sold the car in 2002 and have kept it in the garage or house since then, either stored up in a cabinet or displayed on a shelf.
    This oil could perhaps be close to 40 years old this year.
    Usually it’s Mobil1 for me these days.
  18. Apr 1, 2018 at 3:27 PM
    #38
    I am Root
    I am Root UID 0
    Root
    I am root
    pir897 likes this.
  19. Apr 1, 2018 at 3:42 PM
    #39
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    I went with Idemitsu Full Synthetic 0-W20. 5 quart jug is 23.00 free prime shipping. I got 6 jugs so I guess I'll be running it for 5 rounds. Reportedly, Idemitsu oil is what comes in factory Subaru, Mazda and Toyota oil jugs, but it's much cheaper in bulk.
  20. Apr 1, 2018 at 3:51 PM
    #40
    Orangecrush
    Rob
    Abq NM
    17 OFFROAD Taco SB
    How do you get that rebate??
    shakerhood[QUOTED] likes this.
