AmsOil made a believer out of me.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SRBenjamin, Jun 2, 2021.
  1. Jun 2, 2021 at 9:26 PM
    SRBenjamin
    SRBenjamin [OP] Well-Known Member
    Benny
    Amsoil made a believer out of me, and it only took 45 years.
    I've been running Synthetic fluids for over 40 years, but never ran Amsoil because I could not just walk into a store and buy it.
    A friend talked me into buying some from him, so I said ok!
    When I bought the 2020 SR in late 2019, I installed new 10 ply tires a few weeks later.
    The tires were on the noisey side, so I changed the rear diff with some RedLine synthetic 75/90. It helped but I could still hear it at highway speed.
    A few days back I installed Amsoil 75/110 and the noise is almost gone.
    I guess the tires transfer the noise thru the diff and into the cab. The Amsoil has seemed
    to dampen the vibs/noise.
    So I'm very pleased with the Amsoil.
    TartanEagle likes this.
  2. Jun 2, 2021 at 9:30 PM
    XKC
    XKC Active Member
    Iowa
    2021 Cement Tacoma TRD Sport 4x4
    I guess my question would be how can you prove it's the brand vs the change in viscosity. I would think the difference there far outweighs the difference in additives from Amsoil vs any other brand of the same weight spec.
    WoodsGhost, C41n, antlab67 and 11 others like this.
  3. Jun 2, 2021 at 9:41 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I’ve used redline in my diffs and tranny. No vibes at all, just a very faint hum at 55-60, can barely hear with windows down and music off.
    My buddy with a 19 OR wants to convert to amsoil all of a sudden, says someone he knew told him that’s it’s the best oil.
  4. Jun 2, 2021 at 11:25 PM
    SRBenjamin
    Benny
    No dought it's the best, but it's harder to find and cost too much. I still think Pennzoil Ultra Platinum is the best for the money. I will continue to use it in the engine.
    FYI, About 25 years back I ran Redline MTL in my Toyota 85 4x4. A year after the change, the trans lost a couple of bearings.
    I tore down the trans and replaced all of the bearings with new Japanese replacements. Put in new MTL and two years later I had bearing noise again.
    This time I took it to Marlin Crawler and had him rebuild the trans with a very low
    first gear added, and a 2nd transfer case. When I asked about the bearing noise, they told me it was a lack of lubrication. I ran Q State 75/90 after that, and the trans went another 12 years without issue.
  5. Jun 2, 2021 at 11:26 PM
    SRBenjamin
    Benny
    I would not waste my time trying to prove anything. I just know it works for me.
    1776Taco likes this.
  6. Jun 3, 2021 at 12:22 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    did you accidentally press recirculating air button?
  7. Jun 3, 2021 at 12:31 AM
    White_lighting
    White_lighting Active Member
    Tim
    PHX,AZ
    2017 white Tacoma TRD MT
    Alpine designs CMR, camburg uniball uppers, ADS 2.5 ext travel coil overs with ADS 2.5 Piggy Backs in rear, Headstrong 3 Leaf ADL with Modified Over load for 2" Lift in rear, Raceline Clutch wheels, nitto ridgegraps 33”, SDHQ hidden winch mount, RPM Sliders, HF Apex Winch, HF Trailer tool box with Bolt Box latch, Full Kicker door speakers with Subaru Tweets, Mob Armor Phone Mount, Clutch Accumulator Delete, Carven Cat Back, HPS intake Tube, K&N Drop In filter, Removed Carbon Filter, JLT Catch can, TRD PRO Grill & Tail Lights, Modified Spare Tire Carrier, State 48 Rear diff breather Extension, Dual USB Mod for Cigarette Lighter Always on 12 Volt power "Future Plans URD Y pipe, 34's, Supercharger, Full Skids, Extended Capacity Fuel Tank, PRP race seats up front With Matching Rear Seat Covers"
    I did full amsoil fluid change and the whine on my truck went away, I have been using Amsoil for the last 6 years in all my trucks, I turned into a believer when I had my 03 Chevy 2500 with 496 big block always had low oil pressure with other oils went to amsoil and oil pressure increased, traded that truck in for my taco with 185,000 miles was still running strong no mechanical issues with motor. Amsoil is the best.
  8. Jun 3, 2021 at 10:41 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Been using their severe 75-90W gear lube for years in my toyota's...imo its hard to beat.
  9. Jun 3, 2021 at 10:44 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Picked up a mile per gallon switching over to all Amsoil in my 3/4 ton truck, pretty good for a 4 ton vehicle.
    TartanEagle and SandyTaco4x4 like this.
  10. Jun 3, 2021 at 10:55 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol no. Viscosity helped you not Amsoil.
    WoodsGhost, Kev250R, antlab67 and 4 others like this.
  11. Jun 3, 2021 at 10:58 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Multi level marketing at its best. Amway for men. I also heard that Amsoil cures covid and cancer at the same time.
    WoodsGhost, Kev250R, antlab67 and 9 others like this.
  12. Jun 3, 2021 at 11:53 AM
    SRBenjamin
    Benny
    Also cures Aholes, you should try it.
  13. Jun 3, 2021 at 11:55 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
  14. Jun 3, 2021 at 12:41 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    probably has to do with the weight not the brand
    XKC, hiPSI and Junkhead like this.
  15. Jun 3, 2021 at 12:45 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Interesting. I’ve had redline MT90 in my tranny and diffs for about a year and it’s good so far. Tranny seem to be a bit smoother.
  16. Jun 3, 2021 at 2:20 PM
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    I am also a big fan of Amsoil, but for a different reason.
    I started using Amsoil engine oil and gear lubes around 1996 or 1997 in a Ford diesel pickup I had. I sold that truck in 2000 and bought a brand new Dodge Cummins. I immediately went to all Amsoil oil and lubes in that vehicle. I sold that truck in 2015 (142K miles on it) to a guy who is a professional mechanic and a local race car driver (midgets, street stocks). I had never had any work done on the engine during the entire time I owned that truck. The new owner wanted to do a pretty thorough assessment of it, so after he bought it, he took the head off to check the internals. The Cummins (at least the 1999-2002 model year engine) is a sleeveless cylinder block. The new owner asked me what oil I had been using in the truck, I told him Amsoil. He texted me a couple pictures of the insides of the cylinders, where even after 142K miles, you could still easily see the original factory cylinder hone marks. That made me feel quite good about my years of using Amsoil products.
    I realize this doesn't mean that Amsoil is magic, and all other synthetics could not have done the same, but it did prove to me that Amsoil is a very good product. I have never used Mobil-1, Royal Purple, Redline, or any other synthetics, so I can't make any statements as to how effective other brands are.
  17. Jun 3, 2021 at 2:45 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Amsoil makes a good product. So does many other manufacturers.
    For the 117th time, I have never ever heard of a motor that failed due to the name of the brand of oil. Use approved oil. Use correct viscosity. Change it at regular intervals. That's all. Brand is unimportant.
    The OP got results because he changed viscosity, not because it is Amsoil.
  18. Jun 3, 2021 at 2:56 PM
    Sungod
    St Augustine
    Nothing wrong with the product. It is oil. The issue is that they fill your head full of nonsense to make it sound superior and that comes at a price. The price is the pyramid scheme that it is. Who are the people saying it is great? Those that are selling it. They convince the buyer that their product is superior so they keep buying it and more importantly start selling it so they get a cut. That is how it works. The prime target is someone that is fanatical about their cars, but doesn't have a lot of technical knowledge. Amway and herbal life are the same way. Decent products at inflated prices to cover the pyramid. That isn't to say that traditional marketing isn't better. Lord knows that Mobil makes money touting their products. The difference is they don't rely on someone that really doesn't know a whole lot to make outrageous claims that really can't be supported.
    If you want to see the ridiculousness of multi level marketing look at this property - 19 S Roscoe Blvd, Ponte Vedra Beach, FL 32082 | Redfin The owner sold amway.
  19. Jun 3, 2021 at 2:57 PM
    anthemAnathema
    anthemAnathema Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    Elka 2.5 w/ DSC RCI Skids AP Expedition Leafs Leer 180
    I went full amsoil last 30k service, can't tell one iota of difference except substantially less money in my bank account.
    I did save one of the flexy bags to fill with oil from a rigid bottle for next service, that's the only thing amsoil has going for it. As soon as someone starts manufacturing a fluid transfer pump that doesn't suck balls, I'll toss the amsoil flexy bag.
  20. Jun 3, 2021 at 3:00 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Mityvac MVA6851 Fluid Extractor, Manual, 7-1/2 in. L White, Black https://www.amazon.com/dp/B00MPQ8RBG/ref=cm_sw_r_cp_api_glt_fabc_FH7FTZ0R051H33FFY96B
    Worth every penny
