Amsoil Products ATF, MTF, Gear Oils
Discussion in 'Buy / Sell / Trade - Other' started by Pablo8, Nov 22, 2019.
  1. Nov 6, 2020 at 8:06 AM
    #81
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Thank you so much. Did you get the dimple plug instead of the hex plug @Grossomotto suggested? Because of the copper crush washer?
    Really appreciate the shopping list.
    CygnusX191 likes this.
  2. Nov 6, 2020 at 8:17 AM
    #82
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Not sure which plug he recommended! I better look around. I just have used a lot of Dimple plugs over the years and a) they work fine, no issues, plus b) That magnet will pull scrap iron from the junkyard on the opposite side of town. What plug did he recommend, I can't seem to find it?
    The copper washer (comes with Amazon kit) MUST be used, regardless of plug brand - don't use the supplied (usually aluminum) washer from plug company unless it is copper. Trust me, it will leak and you will end up reefing overly hard on a plug that is a PITA in the first place. Evidently Toyota knows this. When the kit arrives (bought two, because I'm that way) - well I for one - first thought: What is the single copper washer for?
    Ensemble88, daveeasa and CygnusX191 like this.
  3. Nov 6, 2020 at 9:11 AM
    #83
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    What would you recommend for an AT as far as transmission fluid and plugs go? Aside from oil and brakes, is there another fluid I should look to have on hand for self-performed MX?
    Pablo8[OP] likes this.
  4. Nov 6, 2020 at 9:23 AM
    #84
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    I've not seen the drain plug on the AT, and I've not seen an aftermarket version.
    For the AT:
    https://www.amsoil.com/p/signature-...c-automatic-transmission-fluid-atl/?zo=515729
    OR
    https://www.amsoil.com/p/oe-fuel-efficient-synthetic-automatic-transmission-fluid-otl/?zo=515729
    What about the Transfer Case?
    mcharfauros and CygnusX191 like this.
  5. Nov 6, 2020 at 11:38 AM
    #85
    daveeasa
    David
    PNW
    As far as the plug, I was thinking of this post where @Grossomotto linked to a plug, wasn't sure which exact plug it was for (diff or transmission) but I remember you had trouble with one of those and wasn't sure what type of trouble I might encounter. I suppose step 1 could be for me to locate and attempt to remove the fill plugs on diffs and tran as a preliminary step to ensure if they are damaged or stuck that I purchase replacements?
  6. Nov 6, 2020 at 11:39 AM
    #86
    CAG Gonzo
    2018 OR DCLB BarRed
    Transfer Case = Diff fluid? That's the at the clamshell for the rear axle, right? Or is that where the transmission fluid goes? I'd also want to be ready to change that.
  7. Nov 6, 2020 at 11:42 AM
    #87
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  8. Nov 6, 2020 at 11:43 AM
    #88
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    OH yes OK I had forgotten. That is alternative stock and is a better and less costly than factory and a lot cheaper than Dimple!
  9. Nov 6, 2020 at 11:59 AM
    #89
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    No TC is special fluid, light MTF like fluid. On the MT it's on the but end of the transmission. I assume the same unit on the AT.
  10. Nov 6, 2020 at 12:04 PM
    #90
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    See above!
    CygnusX191 and BillsSR5[QUOTED] like this.
  11. Nov 6, 2020 at 12:16 PM
    #91
    daveeasa
    David
    PNW
    Sorry, one more question, do the "easy pack" options mean no need to buy/use a pump? And if so do they make it less messy or easier? Did I get my quantities correct here? I'm not sure at all about the TC but will try to read up on that part. Thanks so much for all the help here!
  12. Nov 6, 2020 at 12:22 PM
    #92
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    GREAT question. Save some $ and get the regular bottles. No way in heck for the front can you get the pack in there to squeeze, ditto MT and rear as well as it will take all 4 qts.
    THEN buy this sexy pump: https://smile.amazon.com/gp/product/B07DTS8N7P/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    Best pump I ever used, puts the others to shame.
  13. Nov 6, 2020 at 12:31 PM
    #93
    daveeasa
    David
    PNW
    Assuming this is the rear diff fluid, I didn't see a gallon option?
  14. Nov 6, 2020 at 12:35 PM
    #94
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    My really bad...............gear oils, no gallon option. Sorry!
  15. Nov 6, 2020 at 12:36 PM
    #95
    daveeasa
    David
    PNW
    Cool, thanks, final order as below for @CygnusX191 and other MT peoples, assuming I didn't bungle quantities or product selection:
  16. Nov 6, 2020 at 12:37 PM
    #96
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Oh snaps, that's convenient.
  17. Nov 6, 2020 at 12:43 PM
    #97
    CAG Gonzo
    2018 OR DCLB BarRed
    I think I need to do some digging in the manual to see what's what then come back here to get the juicy details on products.
  18. Nov 6, 2020 at 12:47 PM
    #98
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Not a problem.
  19. Nov 6, 2020 at 5:11 PM
    #99
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    Thanks Paul, as usual, "You do man!".
    Do you have a part #, or link for that Dimple brand plug?
  20. Nov 6, 2020 at 5:17 PM
    #100
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
