An Honest Answer Please.....
Discussion in '1st Gen. Tacomas (1995-2004)' started by LITacoQ, Jun 21, 2017.
  1. Jun 21, 2017 at 2:39 PM
    LITacoQ
    LITacoQ [OP] Well-Known Member
    East Coast
    2003 SR5 Access Cab 2.7 5 speed lunar mist
    Hello all and happy 1st day of summer. I'm looking to replace my tired stock shocks all around with some 5100's. I have spoken with Down South Motorsports as well as Wheelers. The problem is the rear shocks. DSM tells me I can't use the 5100s with stock height, I have to use the 4600's for stock replacement or install at least a 1 inch lift. Wheelers, on the other hand, tell me that 5100's CAN be used for a stock replacement and they will accept 0-3" of lift. Who is right and what problems would occur using the wrong shock? Thanks in advance for any helpful info.
  2. Jun 21, 2017 at 2:40 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    5100s are fine from 0-2".
    0" being stock height.
    Also, order from @HeadStrong Off-Road and you wouldn't have this problem, and you'd save money.
    RyanL, HeadStrong Off-Road and uurx like this.
  3. Jun 21, 2017 at 2:46 PM
    doorsidedown
    doorsidedown Well-Known Member
    ^^^this. case closed.
  4. Jun 21, 2017 at 2:49 PM
    T4RFTMFW
    Only thing I can think of for DSMs answer is that 5100s are valved for lifted applications, whereas 4600 HDs are identical shocks internally and are valved for stock height.
    But, all that aside.. they're perfectly fine.
  5. Jun 21, 2017 at 2:57 PM
    LITacoQ
    East Coast
    Thanks for the reply, but even Headstrong states "NOTE: These shocks are meant for at least a 1" block lift." I am new to lifting my vehicle and figured BOLD letters meant what they said. lol. I figured missing that 1" lift would overextend or bottom out my rear end.
  6. Jun 21, 2017 at 2:58 PM
    T4RFTMFW
    Interdasting.
    Well.. hundreds of guys run them and we haven't heard of any issues.
    Best I can do, now.
    Lol
  7. Jun 21, 2017 at 2:58 PM
    cc350
    cc350 Retired Member
    Depends on if you have 5- lug or 6- lug.
    33-247717, 33-247724
    FITS: 1996-2004 TOYOTA TACOMA 6-LUG 4WD & PRERUNNER 2WD B8 5100 SERIES MONOTUBE SHOCKS
    REAR LIFT: REQUIRES MINIMUM 1" REAR LIFT AND FITS 1"-1.5" Other Part Number: TACOMA REAR SHOCKS
    Gas Charged Shock: Yes Placement on Vehicle: Left, Right, Rear
  8. Jun 21, 2017 at 2:59 PM
    LITacoQ
    East Coast
    I'm a sixer
  9. Jun 21, 2017 at 3:01 PM
    T4RFTMFW
    Didn't realize this was for a first gen truck.
    I was talking about second gens. Ignore everything I've ever said.
    I don't have a clue if they're similar.
    Bennett707 likes this.
  10. Jun 21, 2017 at 3:04 PM
    cc350
    F4-BE5-D560-T0
  11. Jun 21, 2017 at 3:06 PM
    cc350
  12. Jun 21, 2017 at 3:09 PM
    mustangstephen
    mustangstephen raise hell, drink beer
    Stephen
    by da creek
    02 Tacoma TRD
    Homebrew bumpers and sliders, 5100s & Eibachs up front and mutt leaf pack out back, 285s & Wheelers type B, sway bar deleted. Wife's ride: 01 4Runner 4wd sport. Stock with exception of TRD taco coils, and shift kit.
    Why would lift matter? Like the front suspension, the bump stop is still at the same location regardless of lift. Therefore compression is still the same.
    I think they're fine. Buy them from Wheelers since they say they'll work. Also if your'e stock height don't discount the 4600 shocks. Heck they're better than what I'm running in the back currently.
    LITacoQ[OP] likes this.
  13. Jun 21, 2017 at 3:21 PM
    LITacoQ
    East Coast
    A reply from the administrator on Bilsteinlifts states:
    Will these work on stock height 03 tacoma front and rear? answer now
    "Front shocks can lift the vehicle, rear shocks can't and you need rear lift 1-2.5" in order to use the rear shocks
    Bilsteinlifts.com can offer you some items for rear lift starting with 1″ Rear Lift Block https://bilsteinlifts.com/shop/toyo...kit-1995-2014-toyota-tacoma-tundra-1999-2014/ . After installing the shocks you've chosen and the rear 1'' lift block you can gain 2,5'' front lift and 1'' rear lift, whick will level your truck. Please keep in mind, that such lift blocks are recommended for use in case you don't carry heavy loads and do no towing".
    So, you can see my confusion :argue:
  14. Jun 21, 2017 at 3:22 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    If you call and talk to Bilstein they advise the 5100 line only for lifted/leveled trucks due to the way they're valved. The 4600 line is specifically for stock ride height applications.
  15. Jun 21, 2017 at 3:37 PM
    LITacoQ
    East Coast
    Well, I just got off the phone with Bilstein USA, and they reiterated what you just posted. If I am going stock height in the rear, go with the 4600 line. I can still use the 5100s up front on the middle setting for a little lift. Thanks for the info
    eccracer104[QUOTED] likes this.
  16. Jun 21, 2017 at 3:56 PM
    doorsidedown
    Same here man. Sorry to add to your confusion.
    LITacoQ[OP] and T4RFTMFW[QUOTED] like this.
  17. Jun 22, 2017 at 9:40 AM
    2003ToyTaco
    2003ToyTaco Member
    2003 Tacoma TRD 4x4
    3" Suspension lift King Coilovers Wheelers off-road AAL 3 PACK (Stupid Billy 5100s in the rear) Trail gear low profile bumper eBay Spyder headlights ( pretty cool actually) Blinker modded swapped running lights for bljnker. eBay rear LED tail lights.
    Before you buy them. Don't. They suck. I cooked both of them in one day. Still have them on my truck tho. :confused: I had better luck with OEM TRD Billy's.
  18. Jun 22, 2017 at 9:54 AM
    eon_blue
    Azusa, CA
    Just to play devil's advocate here, I've been running 5100s for a year now and I wheel with them at least a couple times a month on 4x4 only trails....even ran the infamous Mojave Rd. for 3 days (trying) to keep up with other TW members running Kings and Icons. I have no issues with their quality. They are what they are, basically a stock shock that can be adjusted for lift. They aren't going to perform like performance coilovers, if you expect them to or treat them like they can then you'll be disappointed. I was actually really surprised after the Mojave Rd trip that mine were still okay, because I pushed them way harder than I felt comfortable with at times.
    Granted, I've heard of many accounts of people with 5100s that start leaking and blowing out with regular use, so maybe I just got lucky with my set. But aside from the fact that they're pretty basic, they get the job done for me. My next suspension upgrade will definitely be Kings though. I get tired of being the guy in the back of the line of trucks when we go wheeling because I don't want to hold up the guys with the performance c/o's, lol.
    If you're looking for a kit that will give you the suspension lift and look you want, 5100s are a decent inexpensive option. If you want performance ability along with that, gotta spend more $$$ and look higher up on the shelf.
    2002Tacoma4x4 likes this.
  19. Jun 22, 2017 at 11:14 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    They are too long and will bottom out at full stuff.
    AssBurns likes this.
  20. Jun 22, 2017 at 12:47 PM
    2003ToyTaco
    2003ToyTaco Member
    2003 Tacoma TRD 4x4
    Fair enough Blue. I absolutely had too high of expectations for them. Was running them in 100+ degree weather hauling a$$. If you need a basic off-road capable shock 4600 or 5100 are a good bang for the buck.
    My expectations were set high by my yellow and blue OEM shocks and other heavy duty Billy's that were more than capable off-road and lasted a long time.
