An Unusual Steering Clunk Fixed
Discussion in 'Suspension' started by JFriday1, Oct 7, 2024.
  1. Oct 7, 2024 at 6:35 PM
    JFriday1
    JFriday1 [OP] Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    https://youtu.be/zArfW-0bWzM?si=9QxWLWcOGBrslv0I
    This fixed my steering clunk that was very similar to loose camber/caster bolts in sound. I had been slowely chasing the sound for a while now. 19 tacoma.
    Took the front diff brackets off and lubed everything. Bushings and sleeve was in perfect shape. I also trimmed the driver side Rad support bracket as well bc the bolt and washer was very close to the bracket.
    Canadian Caber likes this.
  2. Oct 8, 2024 at 9:20 PM
    r3k
    r3k Well-Known Member
    what grease did u used?
    i'm having the same clunk. thank you for this.
    JFriday1[OP] likes this.
  3. Oct 9, 2024 at 6:47 AM
    JFriday1
    Jesse
    Lakewood, CO
    Just regular grease with moly in it. I think that anything should work, or you can get the real tacky grease from Energy Suspensions.
