Analyze my research...Lift setup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SxDx, Jun 16, 2011.
  1. Jun 16, 2011 at 12:54 PM
    SxDx
    SxDx [OP] Well-Known Member
    TX
    Hey TW whats up. Been lurking and reading for a while now. Wanted to get answers through reading before actually posting. I have a 2011 Double Cab Short Bed Prerunner, and i've been considering lift options since I bought it last month.
    From what I have researched I've put together a lift which I think would suit my needs...(moderate offroad/beach access for surf fishing).
    Here is what I have in mind...your input/suggestions are appreciated.
    Front:
    Camburg 4" Spindles w/ extended brake lines.
    Rear: Allpro or Deaver 3" leaf pack and 5100 shocks.
    I plan to run my factory TRD wheels for now, wrapped in 285-70-17 KM2's.
    Now here's where Im kind of stumped, I know that the camburg spindles push the wheel out 3/4" per side, so does anyone make a .50" wheel spacer to make it a total of 1.25" ?
    I can then order the spidertrax 1.25" for the rear and have the same width front/rear.
    As I said any corrections/suggestions is appreciated. I chose the camburgs because ride quality is important and also because of the positive reviews i've read on here. The fact that I can still add 5100's in the future set at 0 or the first clip for an improved ride is a plus as well.
    Thanks!
  2. Jun 16, 2011 at 1:03 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    With a 3" leaf pack in the rear, you might be happier with a little longer shock,
    Downsouth Motorsports or Wheelers can help you out here.
    Hard to get a good 1/2" wheel spacer because its too thick for the stock studs, but too thin to provide new studs ala spidertrax.
    Looks like you're on the right track overall.
  3. Jun 16, 2011 at 1:05 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Eh on reflection, I don't think I'm right about rear shock length. But I can't easily edit my original post via iPhone.
  4. Jun 16, 2011 at 1:27 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I think you need at least the 1.25" spidertrax in front to clear your tires off the spindle cuz ur running stock wheels.
  5. Jun 16, 2011 at 3:51 PM
    SxDx
    TX
    So I will need to clear the spindle as well as the A-arms with those tires?
  6. Jun 16, 2011 at 3:53 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Actually, I forgot what you need to clear, but I installed spindles on jacob.woods' truck with his stock wheels and the tires rubbed BAD without spacers, so bad bad that he couldnt leave my driveway so I slapped my spacers on his truck
  7. Jun 16, 2011 at 4:03 PM
    SxDx
    TX
    So the spacers did help clear his rubbing issues? i dont mind installing 1.25" up front, i just didnt want it to stick out 1.25" plus 3/4" and look really wide.
  8. Jun 16, 2011 at 4:04 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    maybe this is a stupid question but would new wheels with different offset from stock be better than spacers?
  9. Jun 16, 2011 at 4:08 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    yes the spacers fixed all rubbing issues with the stock rims. he got aftermarket wheels with lower backspacing and gave me back the spacers
