Anchor brand transmission mount
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98 Taco Max, Aug 25, 2016.
  1. Aug 25, 2016 at 7:25 AM
    98 Taco Max
    98 Taco Max [OP] Well-Known Member
    Max
    Calgary, AB
    v6 Tacoma 4x4
    Anyone used this "anchor" brand of trans mount before? It's $60 versus the $200 that Toyota wants for an OEM mount. Wondering if they are junk or are able to hold up while wheeling at all
    I Would prefer not to go to poly mounts, also trying to only replace the trans mount and leave the motor mounts alone
  2. Aug 26, 2016 at 2:01 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I am using the one from 4X Innovations and quite happy. With the Original Motor mounts
    If you don`t like the Poly bushings the only other one I would use would be Toyota
  3. Aug 26, 2016 at 2:59 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Sorry to hi-jack, but what symptoms did you guys notice that made you aware you needed an new support?
  4. Aug 26, 2016 at 7:59 AM
    98 Taco Max
    Max
    Calgary, AB
    v6 Tacoma 4x4
    thanks for your input, i have seen the 4x one and it looks good. so you have one poly mount in the rear and stock engine mounts? I wasn't sure if having poly in one mount and stock ones in the front would have any negative effects? i think i read its best to keep them matched up but if there's no weird vibes or anything then thats good to know
    no worries. my gear shifters (5 speed trans) started moving around a lot more under throttle and i get an occasional minor clunk when accelerating after shifting up gears. got under the truck and i can push the trans and the rubber pieces on the rear mount have some small splits in them and allow a fair bit of play. its not completely broke yet, could probably drive on it for a while still but i want to go abuse my truck on some trails without messing anything up
  5. Aug 26, 2016 at 12:11 PM
    Adirondacktaco
    Adirondacktaco Member
    04 TRD 5spd 6cyl
    I tried an "Anchor" mount on one of my other rides ( 1st Gen Escape) and most of the bolt holes wouldn't line up so I returned it. Bought OEM for the big $$ but it fit correctly. Hope this helps.
  6. Aug 26, 2016 at 1:19 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Myself the clutch was being changed I like Adam I bought a few of the mounts
    Mine has been in 50,000 miles plus
    I guess if one is Super Anal and things need to be perfect the different mounts might be a problem
    I run poly trans mounts on my mid eighties Toyota 4x4`s and the stock motor mounts
    My vehicles get used they are not pretty perhaps one day I can own a vehicle pretty much all one color !!
  7. Apr 5, 2018 at 6:12 AM
    Iowa TRD
    Iowa TRD Member
    2001 Tacoma TRD 4X4
    I am in need of new rear transmission mount and was wondering if anyone has given the Anchor brand a try since this was posted a few years ago. I am thinking of giving it a try as long as it bolts on without any problems.
  8. Apr 5, 2018 at 6:15 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I replaced one on a pre runner and fit fine.
