Anchor points on bed rails 2020 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sabotfamily, Mar 15, 2025.
  1. Mar 15, 2025 at 2:39 PM
    sabotfamily
    sabotfamily [OP] Member
    Sabot
    2020 Tacoma Limited Gray
    BF Goodrich All terrain ko2, Predator steps, Leer bed cover
    I'm considering buying a 2020 Tacoma that has anchors on the bed rails. The anchors aren't like my old Tacoma, which was stolen. See attached photos.
    I looked around on the forum, but didn't find references to those specific dowel-like anchors.
    Can you guys let me know if you're familiar with them? Thanks, folks.
  2. Mar 15, 2025 at 3:50 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Was that used for a Tonnue (sp?) type bed cover. Those are not tie downs like the ones I have which are movable along the rail.
    musicisevil likes this.
  3. Mar 15, 2025 at 4:00 PM
    sabotfamily
    Sabot
    Yeah, I also had the sliding rail type for my tonneau cover which was a hard bed cover. These are strange, fixed placement anchors. ~Thanks
  4. Mar 15, 2025 at 4:43 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Looks to me like someone removed the oem rails.
    You probably need to replace the oem bed rails and oem are good and you can then use oem anchors.
    Maybe used on a web site.
  5. Mar 15, 2025 at 5:08 PM
    Spankomatik
    Spankomatik Well-Known Member
    JD
    IL
    2021 celestial silver metallic AC SR SX 4x4 2.4L
    Fog lights, switch panel, cab storage platform
    I don't know, man. The OEM rails seem to be right there. You can even see the plug at the end. Unless I don't know what I'm talking about. I am also a little stoned.
    Edit: it's probably both.
    Edit edit: I think they're for the OEM tonneau cover. https://www.tacomaworld.com/threads...require-cutting-holes-in-bed-rail-cap.412198/
    musicisevil and Malvolio like this.
  6. Mar 15, 2025 at 5:14 PM
    canuck guy
    Alberta
    23TRDOR
    Ya you're right I think.
    Something isn't 100%.
    My tonneau is covered in snow or I'd send you a pic of mine.
    Hopefully someone else will jump in.
    sabotfamily[OP] likes this.
  7. Mar 15, 2025 at 5:32 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I think the oem rails are there. The other pin style are from something else. I have a solid trifold that would work with the existing oem rail. The other. I have no idea but as a note would be interested in what the heck they are used for.
    sabotfamily[OP] and Malvolio like this.
  8. Mar 15, 2025 at 5:50 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    everything highlighted is for the OEM tonneau cover, which was a port-installed option.
    you can try to check the for-sale section to see if anyone is selling one to make use of it, otherwise, there's a few threads about removing them, and then also replacing the bed rail caps so the openings no longer exist.
  9. Mar 15, 2025 at 5:59 PM
    jss1975snow
    jss1975snow Well-Known Member
    Jamey
    Delaware
    2018 Tacoma TRD OFFROAD
    For the OEM tonneau cover which is missing for you
