and and e brake light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by j83soldier, Aug 16, 2014.
  1. Aug 16, 2014 at 3:54 PM
    j83soldier
    j83soldier [OP] Well-Known Member
    joshua
    Colorado
    05 tacoma
    anti lock brake disable mod, fogtime anytime mod, Leer Topper, all pro plate bumper, toytec 3 inch lift, bfg AT, rims, piaa 5100's, some double din head unit (cant remember), warn 8000 winch, DO sliders, hacked frame to fit full size spare, thule and yakima roof racks
    My abs and e brake light just came on. E brake is off and abs works any ideas or tips on how to check the sensors. My fuses are good
  2. Aug 16, 2014 at 3:58 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Left front wheel speed sensor on mine. So I'll guess the same for you.
  3. Aug 16, 2014 at 4:00 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    fluid is full?
  4. Aug 16, 2014 at 6:08 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I'm thinking maybe not. Ensure the reservoir is full to the Max line, if it is low, check for leaks and check the front brake pad lining thickness. Worn pads mean the caliper pistons extend further, and that uses fluid from the reservior.
  5. Aug 17, 2014 at 5:53 AM
    j83soldier
    joshua
    Colorado
    05 tacoma
    Its not the fluid
  6. Aug 17, 2014 at 5:54 AM
    j83soldier
    joshua
    Colorado
    05 tacoma
    How do I check the sensor. Would that cause my abs and e brake light come on
