And I Thought Toyotas Were A PITA To Change The Oil...
Discussion in 'Off-Topic Discussion' started by CJREX, Jan 4, 2019.
  1. Jan 4, 2019 at 5:22 AM
    CJREX
    CJREX [OP] Well-Known Member
    Georgia
    Not actually difficult, but with their cartridge type filters they always seem to be messier than a simple screw on filter.
    But the new Ranger apparently takes it up a notch.
    You need to Remove The Wheel in order to change the oil filter.
    Hey, oil change is also the perfect time to rotate the tires.
    Maybe they are just nudging you in that direction?
  2. Jan 4, 2019 at 5:32 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Not surprised. Vehicles are designed by engineers, not the guys who actually do work on them. Always makes me think of the episode of mythbusters when the guys were bitching cause they had to remove a wheel to replace the battery on a car. Valid bitching in my opinion though.
  3. Jan 4, 2019 at 5:39 AM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    I posted this on the 3 gen subforum and took some heat for posting this (aww it's no big deal) and the thread got locked. Hope it fares better for you OP. For the record I think it's dumb to have to do this to change the oil. After 27 years in industrial and institutional maintenance two truisms have come to light.
    A. The more difficult it is to perform the scheduled maintenance, the more likely it will either be half assed or deferred completely.
    B. The more steps one has to take in performing that maintenance task, the more likely it will get screwed up in some fashion or another.
    Your mileage may vary.
  4. Jan 4, 2019 at 5:50 AM
    CJREX
    Georgia
    Yep, just wait 'til the Quick Oil Change guys start doing this
    JNG[QUOTED] likes this.
  5. Jan 4, 2019 at 6:00 AM
    Texas Aggie
    Texas Aggie Well-Known Member
    Michael
    TEXAS
    2013 SR5 4x4 Lifted
    King 2.5's Front and Rear 700# coil, 2" wheelers aal, 315/75R16 BFG KM3's Pelfreybilt Front and Rear Steel Bumpers, All Pro Sliders, 4.56 Gears
    Look up the oil change for an Audi R8. It’s a major pain and changed my desire to own one.
    thewarriordinghy and JNG like this.
  6. Jan 4, 2019 at 3:44 PM
    Martimus
    Martimus Well-Known Member
    Martin
    'neath a cactus
    2012 PreRunner SR5
    If I recall correctly, my old 2006 Ranger had a similar oil filter location.
    shakerhood likes this.
  7. Jan 4, 2019 at 6:57 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I just don't see the big freakin deal, so you have to take a tire off, what's so extremely difficult about that? Good time to rotate the tires and inspect everything, plus its not like you have to perform this task once a week as its 10K OCIs.
    Hobbs and tcjacado like this.
  8. Jan 5, 2019 at 1:29 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    It’s almost no different than my old 2008 TL, if anything dealerships will make a killing for those that don’t want to bother with it at home.
  9. Jan 5, 2019 at 2:40 PM
    Karate1993
    Karate1993 Well-Known Member
    coloRADo
    '14 TRD Off-road DCSB
    The oil filter location on the 3rd gen 4runners is similar. I don't have to take the wheel off, but I do have to crank the steering wheel all the way and access the filter from the wheel well. It takes a little contorting.
  10. Jan 8, 2019 at 1:44 PM
    CJREX
    Georgia
    I have a floor jack, compressed air, and an impact gun so taking tires off is no problem.
    Using the factory jack and lug wrench would royally suck.
  11. Jan 8, 2019 at 1:45 PM
    tcjacado
    tcjacado Well-Known Member
  12. Jan 8, 2019 at 1:47 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    literally already been addressed, you can just crank to wheel one way or the other and reach in there, same shit with new gen cummins. its honestly easier than having to jack up the vehicle and crawl underneath.
    edit: might be messier if your a n00b but its not the end of the world to do a wheel well oil change.
  13. Jan 8, 2019 at 2:11 PM
    CJREX
    Georgia
    If you're able to do it by just turning the wheel, then that's no biggie at all.
    I've never had a vehicle that you had to do the oil change through the wheelwell.
    I did have a Lincoln MKVIII LSC that required advanced yoga skills and a roll of aluminum foil to change :D
  14. Jan 8, 2019 at 4:24 PM
    shakerhood
    Southern Ohio
    Right, yesterday they admitted it was a fake news story and all you need to do is turn the wheel to the side. Seems like they like making you contort in order to do things anymore.
  15. Jan 9, 2019 at 9:48 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Pretty much the same as the procedure on the 3.4 V6.
  16. Jan 10, 2019 at 2:46 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    I'm guessing that there aren't too many aircraft mechanics in this thread.....
    The more complex a machine becomes, the more involved the maintenance and repair becomes.....
