Anderson Engineering Manifold Spacer install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Great Dane, Apr 16, 2023.
  1. Apr 17, 2023 at 8:46 AM
    Firn
    Firn Well-Known Member
    White OR
    Harmonics are the major item at play here. The longer runners resonate at a lower frequency and thus move the output lower in the RPM range. This is not something a tune can change as it is a mechanical function of intake runner length. The ACIS valve does impact this but it is only switching between long runners and short runners, this spacer just lengthens both of those slightly. Here again a tune cannot affect much since the ACIS is open or closed and cannot change the mechanical length of the runners themselves.
    Again, harmonics, or resonant frequencies, are in fact the major reason longer runners move power around. The moving airmass does have a minor impact but isn't much since everything you gain in having a larger moving airmass is also lost trying to GET that larger airmass moving in the first place.
    A tune complements this but neither are a replacement for the other.
  2. Apr 17, 2023 at 10:29 AM
    Johnny Lawndart
    Johnny Lawndart Active Member
    2001 SR5, ExtCab, 4wd, 4cyl, stick
    @Great Dane , this is excellent. Thanks for posting. Since you'll be doing a performance-before/after post for this, can you tell us if you did the same with your K&N intake? I'm starting with this spacer, but adding the intake next if it's worth it. I'd do both at once, but i really like to know what works and what doesn't, and how much, if at all, etc.
  3. Apr 17, 2023 at 5:04 PM
    Great Dane
    Great Dane [OP] Well-Known Member
    Dane
    Georgetown, Ky
    2021 TRD Sport 4x4 Access Cab.
    I wound up not using my torque wrench and using the German measure of torque, aka Gudentite.
    I didn't do the same with the K&N and the AFE throttle body spacer, and this is why:
    My truck is a '21, and I ordered it. While I was waiting for it, I bought parts for it, to include the K&N air intake and AFE throttle body spacer. I picked the truck up with 3 miles on it, and it had 44 miles on it when I got it home.
    The next day, I started putting parts on it, to include a URD catless midpipe, the air intake, and the throttle body spacer. I ordered the truck with the TRD catback on it. So I never really drove it as a stock truck, except for those first 41 miles getting it home.
    Since then I've also added a KDMaxx tune to it. And then this Manifold spacer.
  4. Apr 17, 2023 at 5:20 PM
    Great Dane
    Dane
    Georgetown, Ky
    So...........I had to pick up a couch today, so I got a chance to put some miles on the truck and see what if any improvements this spacer made.
    I'm glad to say that it was money well spent. I could actually notice that torque came in around 2000 rpm, and it took even less pedal to keep the truck at speed, even with the KDMaxx tune. The truck is also more pleasant to drive now.
    I'm looking forward to putting the one I have for my 4Runner on now.
    I highly recommend this.
    DakoTaco, PandaYota, Dfpftw and 6 others like this.
  5. Apr 17, 2023 at 5:29 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Would be fun to stack 2, for troll factor.
    vivid02, Dfpftw, CRCs Reality and 2 others like this.
  6. Apr 17, 2023 at 6:02 PM
    Great Dane
    Dane
    Georgetown, Ky
    I really think that would cause hood clearance issues.
  7. Apr 18, 2023 at 11:28 AM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Any additional feedback on how the spacer changes the driving experience?
  8. Apr 18, 2023 at 11:49 AM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Waiting for the 4.7 release for my 4runner.
  9. Apr 18, 2023 at 11:56 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Sounds like Yelp review. anything of the substance?
  10. Apr 18, 2023 at 12:02 PM
    DWD484
    DWD484 Could Be Joking
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    Butt-Dyno Certified!
  11. Apr 18, 2023 at 1:21 PM
    Firn
    White OR
    Still trying to figure out what more of substance, or not-a-butt dyno, someone is expected to provide simply from a test drive....
  12. Apr 18, 2023 at 1:31 PM
    Great Dane
    Dane
    Georgetown, Ky
    If you're looking for dyno results, sorry, but you won't get those here.
  13. Apr 18, 2023 at 2:28 PM
    Vlady
    Issy, WA
    OP state the torque came around 2000 with a less pedal . Where the torque was before? What was TPS and engine load before and after. You don't need a dyno to see affect.
    FYI, if you reset ECU learning values or reflush the tune, the truck will drive like a dream for a few
  14. Apr 18, 2023 at 2:34 PM
    Firn
    White OR
    He said he noticed a difference. If you want specifics then pay for a dyno because that is the only thing that counts. Some guy on the internet saying "will, at a sustained 28.3% throttle it FELT stronger at 2000 rpm" means as much and as little as "felt stronger down low".
    Superdave1.0, ClassyTacos and 02Duck like this.
  15. Apr 18, 2023 at 2:47 PM
    #35
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Ya but the intake under the hood pulling in heated air? I kinda thought the Tacomas already came with true cold air intakes? :anonymous:
    Barsoom and TS4x4 like this.
  16. Apr 18, 2023 at 2:49 PM
    #36
    Vlady
    Issy, WA
    Ok, is this reference to accelerator or throttle? And in which gear?
  17. Apr 18, 2023 at 2:52 PM
    #37
    SoCaltaco65
  18. Apr 18, 2023 at 3:08 PM
    #38
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I suppose it's a good thing he's asking for log data and not their opinion on how it "FELT".
    Junkhead likes this.
  19. Apr 18, 2023 at 3:25 PM
    #39
    DWD484
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    I can run way faster in my Nike’s as opposed to my Adidas.
    vivid02, ClassyTacos, MadKatt and 2 others like this.
  20. Apr 18, 2023 at 3:27 PM
    #40
    SoCaltaco65
    Now is that before or after you drink a Red Bull and get wings....
    Junkhead and DWD484 like this.
