Anderson Engineering Manifold Spacer install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Great Dane, Apr 16, 2023.
  1. May 15, 2023 at 1:17 AM
    #61
    Great Dane
    Great Dane [OP] Well-Known Member
    Dane
    Georgetown, Ky
    2021 TRD Sport 4x4 Access Cab.
    Still putting a smile on my face. Nothing has changed. It's still doing what it's supposed to do, and I'm still enjoying the fact that it is.
    I still highly recommend.
    McFlysRide, riggityj, 02Duck and 2 others like this.
  2. May 16, 2023 at 5:26 PM
    #62
    Dfpftw
    Dfpftw 1luv
    SoFLA
    SoFla
    Red DCLB Tacoma
    Trd intake stuff More intake stuff Kdmax pro 10.0 yayayaya
    Yo the adaptive cruise feels so much better with the Mani spacer on the interstate. I’m straight chilling 85mph left lane. Also I haven’t seen anything under 18mpg city’ after install.
    riggityj, PhogDog and Firn like this.
  3. May 16, 2023 at 6:29 PM
    #63
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    That's where it interests me! (+towing)
  4. May 17, 2023 at 1:16 AM
    #64
    Great Dane
    Dane
    Georgetown, Ky
    I haven't taken a trip long enough to set the cruise control for...........yet.
  5. May 17, 2023 at 1:03 PM
    #65
    Dfpftw
    Dfpftw 1luv
    SoFLA
    SoFla
    Red DCLB Tacoma
    We’ll find your local Buckees and get going lmfao
  6. May 17, 2023 at 1:05 PM
    #66
    Dfpftw
    Dfpftw 1luv
    SoFLA
    SoFla
    Red DCLB Tacoma
    Do. It. Be mindful of the harness and the far back bolt. I was wrestling it for a bit. Get the harness out the mfin way. GGs
  7. May 17, 2023 at 1:07 PM
    #67
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  8. May 17, 2023 at 1:17 PM
    #68
    Dfpftw
    Dfpftw 1luv
    SoFLA
    SoFla
    Red DCLB Tacoma
    You’re one of those cali” blokes huh mate ? I reckon no one takes you serious.
  9. May 17, 2023 at 2:55 PM
    #69
    Great Dane
    Dane
    Georgetown, Ky
    LOL!!!
    Already know where it is. As soon as I finish the update on my stereo, I'll be doing just that.
  10. May 20, 2023 at 9:54 AM
    #70
    ricco333
    ricco333 Active Member
    Erik
    2021 White SR5/4x4
    First and foremost thanks to those who installed it and provided the useful feedback in the most basic form, the butt Dyno. My question is I have already flashed my ECU with the Overland Tune, if I install the spacer do I have to reflash my tune or reset anything before I can see the results?
  11. May 20, 2023 at 10:40 AM
    #71
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    You should not need a reflash.
    ricco333 likes this.
  12. May 20, 2023 at 12:18 PM
    #72
    Firn
    Firn Well-Known Member
    White OR
    You should see results without any changes to the tune.
    Theoretically, refining the tune for the spacer should give even more benefit.
    ricco333[QUOTED] likes this.
  13. May 20, 2023 at 6:49 PM
    #73
    Great Dane
    Dane
    Georgetown, Ky
    You won't need a reflash. I have a KDMaxx tune on mine, and I noticed the difference immediately.
  14. May 23, 2023 at 9:09 AM
    #74
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Butt dyno reports, from both tuned and untuned have me convinced to try it. I live in south of Pittsburgh, so having a bit more low end will be very noticeable right off the bat. But first I need to see about some random stumbling/bucking under light acceleration out of a sharp turn. My scanner isn't showing any codes, but I have a hard left turn on my daily drive home that consistently results in this behavior, and I'm wondering if the stability or traction control modules are doing something wonky.
  15. May 23, 2023 at 11:22 AM
    #75
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    too high of a gear, not enough accelerator input to force a downshift. think, manual transmission or motorcycle in wrong gear. doubting the spacer with completely fix the bucking. best to drive in town in S4 below 50, or S5 below 65. good luck, some of us have been fighting this a long time. more than likely a torque converter lock up, or shudder issue. Ski
  16. May 23, 2023 at 11:30 AM
    #76
    Firn
    White OR
    ha, my MT does it when in the correct gear... I would argue 2000-3500 rpm isn't "too low" of an RPM to open the throttle but the computer already severely limits the amount the throttle blade opens at "low" RPM.
    skidooboy[QUOTED] likes this.
  17. May 23, 2023 at 11:36 AM
    #77
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Correct, on ATs the issue is related to the TC solenoid is switching ON and causing 200 rpms drop.
    I belive the person has MT.
  18. May 23, 2023 at 4:54 PM
    #78
    Toy_Runner
    99 4Runner SR5
    Mines a manual, it's a turn I can usually drift through about 15-20mph, dropping from 4th to 2nd, and accelerating up the incline of the hill. I'm not mashing the pedal to the floor, but I'm not not giving throttle input either. If I have to come to a stop before turning due to traffic, it will exhibit the same behavior after upshifting to 2nd. The hill starts with a gentle but increasing slope, no bumps or curbs to drive up over. Its actually currently being repaved, so it has to be something with the combination of bodyroll and differing wheel speed.
  19. May 23, 2023 at 5:44 PM
    #79
    Firn
    White OR
    Is yours a third gen?
    If TC engages on mine there is a ton of racket from the firewall region. I actually hear the TC engaging before I feel it
  20. May 23, 2023 at 6:44 PM
    #80
    Toy_Runner
    99 4Runner SR5
    Yes, '22. Not quite 10k on it yet, picked it up at the end of september. I've posted about the lurching/lugging under similar drivong conditions in the MT accumulator thread. My first two checks for signs of driveline slop/failed u-joints, loose bolts, etc didn't show anything amiss. I'll have another chance to check everything over this weekend.
    I don't hear anything clicking/popping, I just get this forward/backward shimmy like it's bouncing the rear axle, and it's not bumps in the road causing it. It's like it's misifiring or cutting power for some reason under light to moderate throttle input.
