Anderson Engineering Manifold Spacer install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Great Dane, Apr 16, 2023.
  1. Apr 19, 2024 at 7:36 AM
    #161
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    out of curiosity, which tune did you combine this with?
  2. Apr 19, 2024 at 7:50 AM
    #162
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    I notice the difference towing. Holds 4th gear with a 5100 lb trailer much better and longer.
  3. Apr 19, 2024 at 8:07 AM
    #163
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    @TacoManOne that's what I'm looking for, improved towing.
    TacoManOne likes this.
  4. Apr 19, 2024 at 9:22 AM
    #164
    TacoManOne
    Paul
    Liberty Lake, WA
    It makes a difference you can tell for sure. Again not dramatic but definitely a noticeable difference.
    atc250r[QUOTED] likes this.
  5. Apr 19, 2024 at 9:36 AM
    #165
    atc250r
    Orange County, NY
    Cool. If they do a sale or a coupon code I'll grab one soon. If not I might wait a bit.
  6. Apr 19, 2024 at 12:23 PM
    #166
    sublimaze
    sublimaze Well-Known Member
    I think I already know the answer, but is it better to install this spacer before getting tuned, or does it matter which is done first? Did anyone need to get their tune adjusted after installing spacer?
  7. Apr 19, 2024 at 12:51 PM
    #167
    atc250r
    Orange County, NY
    When I asked OTT they said it doesn't matter.
    sublimaze likes this.
  8. Apr 19, 2024 at 5:43 PM
    #168
    TacoManOne
    Paul
    Liberty Lake, WA
    Doesn’t matter. I am a Yotawerx/KD max tuner
    sublimaze[QUOTED] likes this.
  9. Apr 19, 2024 at 5:55 PM
    #169
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    do these go on sale? i cant imagine they would
  10. Apr 19, 2024 at 6:16 PM
    #170
    atc250r
    Orange County, NY
    From the PM's I got the certainly do. Let's be honest, while I appreciate the fact that time went into designing this, $325 is a lot for a piece of plastic even if it makes power. The fact I got a discount code got me from "maybe" to "sold".
    auskip07[QUOTED] likes this.
  11. Apr 19, 2024 at 6:22 PM
    #171
    auskip07
    Skip
    Atlanta, Ga
    Also on the fence about this. Its alot of money for what it is.
  12. Apr 19, 2024 at 6:32 PM
    #172
    WiFiDoctor
    WiFiDoctor Well-Known Member
    2021 TRD Pro
    Has anyone mentioned 3D printing one of these in this thread?
    Never mind, you can’t 3d print delrin. Needs to be injection molded or machined.
    Probably best for someone with the access to the right equipment to cnc out of aluminum.
  13. Apr 19, 2024 at 8:02 PM
    #173
    sublimaze
    Yeah I didn't think a spacer would make a significant difference in the tune variables.
    Thanks for the feedback!
  14. May 14, 2024 at 12:43 PM
    #174
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    I asked my tuner about manifold spacers before installing (running CVC tune), and he said the tune will use the truck's learning ability to optimize itself for the spacer over time since the tune is programmed to optimize for small changes like that. My truck initially idled a bit higher after install, but a couple minutes in the driveway idling and it quickly settled back down to near normal RPMs and I noticed after a couple drives the shifting behavior also improved a bit as the tune adjusted for the spacer's effects on airflow.
    So far no changes in my thoughts I posted a month or so back, aside from getting more milage and data in that makes me even more glad I did the install. I'll probably still regear when I go to 33s but right now on 32s the truck feels well set up with just the manifold spacer and a tune. Based off my experience, I think anyone towing regularly or carrying more weight often will appreciate the changes to torque behavior and accessibility even more than me.
    02Duck, sublimaze and BlueRibbonRM like this.
  15. Aug 2, 2024 at 6:35 AM
    #175
    atc250r
    Orange County, NY
    After having the spacer sitting behind the back seat of the truck for nearly 3 months I decided to install it yesterday after work. Install was faster and easier than I expected. I used the double nut method to remove the two studs before removing any of the other manifold bolts which IMO is better than removing them after the manifold is up and you're working between the upper and lower manifolds and having to jam rags in the intake ports to prevent the stud from falling in. I also used a trick from my days as a Mitsubishi tech doing timing belts on Monteros, pull the cores out of the front tire valve stems to make it easier to reach into the engine bay. It gets it about 5 inches lower which helps a lot if your truck is lifted and/or you're vertically challenged like I am. Took 90 minutes from the time I walked outside to start the job to the time I walked back inside and cracked a beer. I'm happy with the results and wish I'd have installed it months ago. Noticeably more grunt from a stop under light throttle and hills that would cause the trans to unlock the torque converter then downshift to 5th now are being pulled in 6th with just the converter unlocking. I wouldn't be surprised if I pick up a mpg or two but unfortunately I forgot to look at the trip average on the screen when I got to work this morning. I'm looking forward to seeing how it does with a trailer behind it or even with the snowmobile in the bed. I feel it was pricey but will be money well spent in the long run.
    StandardTaco, 02Duck and TacoManOne like this.
  16. Aug 2, 2024 at 6:58 AM
    #176
    TacoManOne
    Paul
    Liberty Lake, WA
    Works great with a trailer. Holds 4th with my 5000 lb trailer much better on the flats. Noticeably better.
    02Duck and atc250r[QUOTED] like this.
  17. Aug 2, 2024 at 7:06 AM
    #177
    atc250r
    Orange County, NY
    @TacoManOne thanks. That's what I figured. Hoping to do a 4 hour drive upstate with the ATV on the trailer this month, it's a trip I've done a bunch of times so I'll be able to really feel how different it is.
  18. Aug 2, 2024 at 7:25 AM
    #178
    auskip07
    Skip
    Atlanta, Ga
    I just ordered a supercharger and i never installed my spacer. Ill prob list it on the marketplace
  19. Aug 2, 2024 at 7:28 AM
    #179
    atc250r
    Orange County, NY
    Wish I could have bought a "used" one. It's not like it's a wear item.
  20. Aug 2, 2024 at 9:06 AM
    #180
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    Are there any published dyno results for Before and After?
    shakerhood and TS4x4 like this.
