Anderson Engineering Manifold Spacer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Great Dane, Apr 2, 2023.
  1. Apr 16, 2023 at 10:40 AM
    #81
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    1500 plus the know how of doing it. Did you install yours? I looked into it but it was a little more than what I wanted to take on in my garage.
  2. Apr 16, 2023 at 1:50 PM
    #82
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    I'm not into crawling anymore, so my 2020 is stock. But I did my first ratio change in 88 on my 85, then did it again on my 91 runner, and my 88 LC.
    Not difficult, just takes time and is messy.
  3. Apr 16, 2023 at 1:52 PM
    #83
    Benny22
    20Tacoma
    No hate, just opinion.
  4. Apr 16, 2023 at 2:00 PM
    #84
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    do you have the throttle body spacer too? Is it worth it?
  5. Apr 16, 2023 at 3:11 PM
    #85
    Great Dane
    Great Dane [OP] Well-Known Member
    Dane
    Georgetown, Ky
    2021 TRD Sport 4x4 Access Cab.
    I have a throttle body spacer and a K&N air intake, and along with the KDMax tune, it was well worth it to me.
    Anyway, I just put my manifold spacer on. Not gonna go into detail because I'm about to make a thread about the install.
    So be looking for it.
    ricco333, TRDPRO68 and Dfpftw like this.
  6. Apr 16, 2023 at 3:57 PM
    #86
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    Something to consider. Factory transmission shift patterns are matched to engine rpm/torque values. In other words- if the engine makes the most power between 1500-2500; the transmission gears to accommodate and match. When you change the RPM power curve, you negate how the transmission corresponds with the engine.
    Johnny Lawndart likes this.
  7. Apr 16, 2023 at 4:01 PM
    #87
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Yes and yes Im very happy with the outcome
  8. Apr 16, 2023 at 4:03 PM
    #88
    erok81
    erok81 Well-Known Member
    Imposter
    That kind of goes out the window once you add a tune. I’d assume someone installing this part is going to have a tune as well.
    Rainoffire likes this.
  9. Apr 16, 2023 at 4:04 PM
    #89
    shotgunbilly420
    Now if you reset your transmission learning values you should be fine. I was
    atc250r and Woodythebluetaco like this.
  10. Apr 16, 2023 at 4:05 PM
    #90
    shotgunbilly420
    Also reset ECU learning values also
  11. Apr 16, 2023 at 4:26 PM
    #91
    Great Dane
    Dane
    Georgetown, Ky
  12. Apr 16, 2023 at 6:55 PM
    #92
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Interesting. I hate the lugging/slow response below 2500rpm with my manual. Will have to consider this before flashing the ecu.
    02Duck likes this.
  13. Apr 16, 2023 at 7:59 PM
    #93
    auskip07
    Skip
    Atlanta, Ga
    Are we completely ignoring that it does a shit job at this?
  14. Apr 17, 2023 at 2:52 AM
    #94
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Chris, I'm looking at doing the spacer. Do you need to make adjustments to my current tune or should everything be good to go?
  15. Apr 17, 2023 at 6:55 AM
    #95
    spicy_fish_taco
    spicy_fish_taco Well-Known Member
    '18 2.7L Taco 4x4 Access Cab
    my 2.7 3rd gen does 20-24mpg at 60-70mph average on long trips and thats with hilly terrian on 87 octane. headers is the only mod, riding on 32 inch ko2's...im not sure im understanding your point, can you clarify? sounds like you got scammed
  16. Apr 17, 2023 at 7:24 AM
    #96
    pauldotcom
    Paul
    MA
    Are you ignoring that there are reasons they do what they do? The #1 reason to buy a Tacoma over it's competitors is reliability. You start changing engine settings, tunes, etc, you now have turned the Tacoma into an unreliable Chevy.
    petethemeat likes this.
  17. Apr 17, 2023 at 7:44 AM
    #97
    auskip07
    Skip
    Atlanta, Ga
    wouldnt want to compromise the transmission by having it produce the same torque but at a different rpm. (italicized for sarcasm)
    TS4x4, ClassyTacos and Toy_Runner like this.
  18. Apr 17, 2023 at 8:30 AM
    #98
    pauldotcom
    Paul
    MA
    You are obviously missing the point and clearly uneducated on powertrain basics 101 (no sarcasm)
    I should have realized this prior to my post after reading some other garbage you posted, and I quote, "diff change atleast for a 4x4 is around the realm of 3k dollars. so for 1/10 of that you can get some results and adjust the power band." when discussing intake spacers LOL. Same results? Priceless.
    Dfpftw likes this.
  19. Apr 17, 2023 at 8:38 AM
    #99
    Dfpftw
    Dfpftw 1luv
    SoFLA
    SoFla
    Red DCLB Tacoma
    Trd intake stuff More intake stuff Kdmax pro 10.0 yayayaya
    Lmfao !! This is by far the hottest take/topic about Tacoma. The little spacer. My two cents is everyone who is negative about the spacer thinks it’s changing WAY more than it is. Also with tuning- apparently the KD max pro tune is built/designed by 3 separate retired race car drivers or individuals in the industry. & the dealer can not even tell it’s tune unless you tell them. All is easily returnable to stock too for warranty issues * the tune ?! Is for drive-ability* not MAXIMUM RPM no red line tune. :crapstorm::burnrubber::censored:
  20. Apr 17, 2023 at 8:40 AM
    #100
    Old Man Tan 4x4
    Old Man Tan 4x4 Well-Known Member
    North East
    2017 TRDOR DCSB 4x4
    What a rediculous statement.
    TS4x4, Jerry311SD, Rainoffire and 2 others like this.
