Android app that can read ABS codes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by huff.jeremy, Nov 5, 2015.
  1. Nov 5, 2015 at 5:22 AM
    huff.jeremy
    huff.jeremy [OP] Well-Known Member
    Illinois
    2010 MagGray SR5 Access Cab, 4x4, 2.7L, 5spd
    OME 884's, OME shocks, Wheelers 1.5" AAL, Light Racing UCA, Jason Fiberglass top, URD Short Shifter, Fog Lights
    Has anyone found an Android app that is compatible with the generic OBD/Bluetooth adapters and can read ABS codes on a Taco?
    I have downloaded many apps including Torque, Uscan, Carista,and Bluedriver, but all of these apps either: don't support ABS codes for the Tacoma, or Require an expensive proprietary bluetooth dongle.
    Any ideas?
  2. Nov 5, 2015 at 5:41 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I'm sure you going to need the extra special tool to plug into the vehicles OBDII computer harness. There won't be an app that simply reads into the trucks computer without some form of decent plug in.
  3. Nov 5, 2015 at 7:32 AM
    huff.jeremy
    Illinois
    Thanks for the response, but I probably should have been more clear in the original post.
    I do have a generic/universal $20 connector for the OBD port that connects to a phone's app via bluetooth. But the only apps that I have found that actually claim to read ABS codes require the use of their proprietary bluetooth connector; these seem to be in the $100 range. I have found one app (Carista) that will connect with a generic dongle and read ABS codes, but cannot do so for a Tacoma according to the specs.
    I am hoping that someone has been more successful in finding an app that will connect to the universal dongle and read the ABS codes from a taco.
  4. Nov 5, 2015 at 8:01 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Techstream OBD to usb cable... 25 bucks on ebay.
    Then figure out how to get the techstream software up and running on your laptop and you can read ABS codes all day long.
    Actually used my same setup to read my buddies truck and figure out why his traction control light was on solid after an alignment. This was due to the steering wheel was off centered before then recentered. Did a full traction control sensor reset via the software n boom... errors gone.
  5. Nov 5, 2015 at 9:46 AM
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
  6. Nov 5, 2015 at 9:49 AM
    nd4spdbh
    SoCal
  7. Nov 5, 2015 at 9:50 AM
    braik
    Louisville, KY
    2006 4.0L 4x4 BASE
    Ah, I see.
  8. Nov 5, 2015 at 9:57 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Generic adapters are not going to read vehicle specific codes. That usually requires a more expensive reader programmed with them.
