Android auto 2023 tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2023tacomer, Jun 8, 2024.
  1. Jun 8, 2024 at 11:53 AM
    2023tacomer
    2023tacomer [OP] Well-Known Member
    Well, I can't get android auto to work. 2023 tacoma, trd off road. Shouldn't I see under apps android auto? I have like two apps, wifi and toyota connect. I went through my phone setup, looks like I can make calls and texts only. What am I doing wrong?
    Also, no Bluetooth, has to be a cable?l to connect? I've tried 2 cables, no luck. The phone does charge though.
  2. Jun 8, 2024 at 12:06 PM
    JCox
    JCox Well-Known Member
    Justin
    2021 Tacoma SR5
    It has Bluetooth. To use anything auto you need to be connected by a usb cable. Are you? All of your connections should be under source. Take your time, reset the Bluetooth on your phone, forget device, refresh etc.
  3. Jun 8, 2024 at 12:24 PM
    2023tacomer
    So you are saying I need a cable, but also saying I need Bluetooth which is not via the cable. Either way I have the cable in as I described, and everything enabled. I would think under apps I would see android auto on the dash. I don't.
  4. Jun 8, 2024 at 12:28 PM
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
  5. Jun 8, 2024 at 12:32 PM
    2023tacomer
  6. Jun 8, 2024 at 12:34 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    sounds like user error, you can listen to music without connecting it via bluetooth. but for maps and other apps you need to connect your phone with a usb cable
  7. Jun 8, 2024 at 12:36 PM
    2023tacomer
    Or comprehension issue. I stated I have used multiple USB cables. Thanks
    Blak Shinobi[QUOTED] likes this.
  8. Jun 8, 2024 at 12:38 PM
    hersheck
    hersheck Well-Known Member
    mike
    23 Sport Lunar Rock DCLB
  9. Jun 8, 2024 at 12:41 PM
    Blak Shinobi
    taco
    n/a
    me or you? coz mine works fine lol
  10. Jun 8, 2024 at 12:42 PM
    JCox
    Justin
    2021 Tacoma SR5
    I’m saying that you need a USB cable to use android auto or Apple CarPlay and the vehicle has wireless Bluetooth.. we’re here to help you.. you seem a little on edge. Have you tried refreshing the trucks radio?
    Blak Shinobi likes this.
  11. Jun 8, 2024 at 12:45 PM
    2023tacomer
    Not on edge, just being clear. No, I have not refreshed it. I have never used it. I do have a manual transmission, I would hope that wouldn't matter.
  12. Jun 8, 2024 at 12:47 PM
    Blak Shinobi
    taco
    n/a
    watch this video and connect your phone , everything should fall into place
    https://youtu.be/O9yw9ktjk3k?si=xShaHiTMAprnaluD
    Also m/t doesnt matter
    JCox likes this.
  13. Jun 8, 2024 at 1:11 PM
    2023tacomer
    Have done it. Device not recognized it tells me. I'm not able to use my newest cable since I can't find a usbc to usb adapter. I'm guessing it's my cables
  14. Jun 8, 2024 at 1:42 PM
    Blak Shinobi
    taco
    n/a
    burn those mfs
  15. Jun 8, 2024 at 2:59 PM
    808stateofmind
    Kona
    zero issues. i also put a piece of velco and attached it upside down in the opening for the wireless charger if that makes sense. that way its out of the way, and if you need to remove it its not stuck there with double sided tape
    hersheck[QUOTED] likes this.
  16. Jun 8, 2024 at 3:03 PM
    808stateofmind
    Kona
    i also have a manual transmission, so it should make no difference. could be the adapter youre using on the cable, so get just a cheap basic usbc to a cable. I dont remember exactly how i did it cause its been so long, but im pretty sure there was a setting in the stereo and or the phone to enable android auto. go to the settings on your phone, and in the search area (magnifying glass) type android auto, and see if there is any settings you can enable
  17. Jun 8, 2024 at 3:35 PM
    hersheck
    mike
    you mean like one side of the velcro attached to the underside of the wireless charging hole "roof" and then the ma1 having the other velcro attached to it, right?
  18. Jun 8, 2024 at 4:00 PM
    808stateofmind
    Kona
    Exactly
  19. Jun 8, 2024 at 4:25 PM
    WallyIAm
    WallyIAm Ope!
    WI
    2023 ELM Tacoma TRD OR
    Just to rule out one variable, you tried connecting to the USB port in the dash, not in the armrest storage, correct? The one in storage is charging only.
  20. Jun 8, 2024 at 4:46 PM
    TheMirror
    TheMirror Well-Known Member
    22 TRD Sport 4x4 m/t
    not sure if you've got your answer yet, but a few things to try.
    -reinstall android auto on your phone.
    -go into android auto app on your phone and clear the cache.
    -leave the usb cable plugged in and reset your phone. once you've done this get past the password protection screen and then leave phone on for a moment. once you've done this, reset your tacoma screen by pressing and holding the bottom left knob until it resets.
    this usually does the trick.
    if it doesn't, try a new usb c cable, and the the above process again if this doesn't fix the issue.
