Android head unit, great alternative
Discussion in 'Audio & Video' started by makanouchi, Aug 22, 2015.
  1. Nov 4, 2015 at 6:51 AM
    #41
    SRC
    SRC Well-Known Member
    Shawn
    Guelph, Ontario
    2017 DCSB OR
  2. Nov 4, 2015 at 7:00 AM
    #42
    ChadsPride
    Sponsored by TacomaWorld.com
  3. Nov 4, 2015 at 7:17 AM
    #43
    makanouchi
    makanouchi [OP] Well-Known Member
    Lac
    Austin, TX
    2015 MGM Double Cab Long Bed
    Front Grill, Audio System, Seat covers, Rear bumper, hood struts, Projector Retrofit, Led's throughout. Avid Bumper Guard, Avid Sliders, Bilstein 5100 front and Rear, OME 885, AAL.
    You still need a steering wheel controller to convert the steering wheel signals to a format the head unit can understand. Pax and metra both make one. That harness just makes it easier to hook into the factory wiring.
  4. Nov 4, 2015 at 7:31 AM
    #44
    TRDrh
    TRDrh Well-Known Member
    Richard
    SoCal
    Were you able to fix the mic via Bluetooth issue?
  5. Nov 4, 2015 at 8:14 AM
    #45
    makanouchi
    Lac
    Austin, TX
    Honestly, I haven't looked into it any further. The sound quality is not as good as factory on the other end but it's good enough for me for the 1 or 2 calls I take in the car each week.
  6. Nov 5, 2015 at 1:20 PM
    #46
    w0m
    w0m Active Member
    Pittsburgh
    14 Tacoma SR5
    Looks nice. Is the navigation Google Maps or an App in the store?
  7. Nov 7, 2015 at 8:04 AM
    #47
    makanouchi
    Lac
    Austin, TX
    I tether and use Google maps with the satellite layer turned on, looks very good. The unit also comes with offline maps and nav program.
  8. Nov 9, 2015 at 4:05 PM
    #48
    LB Taco
    LB Taco Taco... since '97
    J
    Long Beach, CA
    '08 Red PreRunner LB- sick!
    Debagded, American Outlaw 17" rims with BFG 265x70, Ipod interface, GC upper and lower grille, black grille surround, Red Devil Horns, relocated horns, A/C mod, Fogs on anytime, Original 40 flowmaster, Hella 500ff behind the grill, with more to come with more $...
    OK, finally installed my Joying headunit. For my 2008 JBL system I did not need any antenna plug converter or aftermarket steering wheel controller. I used the Joying wiring harness and programmed the steering wheel controls at the headunit. It was all plug and play, works flawlessly. Ill post pics later, I used the metra dash kit, it was a pain to install, had to do a lot of trimming, but it came out almost perfect.
    westly7, Priddle and T@co_Pr3runn3r like this.
  9. Nov 10, 2015 at 7:58 PM
    #49
    mds2004
    mds2004 Active Member
    Mark
    Bakersfield, CA
    2010 DCLB PreRunner
    Which harness adapter did you purchase?
  10. Nov 11, 2015 at 8:28 AM
    #50
    SRC
    Shawn
    Guelph, Ontario
    2017 DCSB OR
    @LB Taco did you just tap into the steering wheel control wires like this to make them work?
    KEY 1 to Violet-White
    KEY 2 to Yellow-Black
    GRND to white-red
    I'm hoping I can just straight wire them in and return the adapters I bought.
    Also, did you retain full functionality of the buttons? (volume/skip track/mode)
  11. Nov 14, 2015 at 11:33 AM
    #51
    owen06
    owen06 Well-Known Member
    Hinesville, GA
    16 DCSB 4x4 Red
    How's the built in Nav? Any pics of it?
  12. Nov 15, 2015 at 3:23 PM
    #52
    JL99
    JL99 New Member
    Johnathon
    2009 Tacoma SR5
    Very Interested in this! Thanks OP for sharing.
    Has anyone been able to make Sirius XM Satellite radio work with this deck?
  13. Nov 19, 2015 at 5:38 PM
    #53
    Kturner23
    Kturner23 Well-Known Member
    2010 DCLB sr5 4x4
    Did you have to buy a harness?
  14. Nov 19, 2015 at 5:51 PM
    #54
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Whats BestBuy charging you, if you dont mind?
  15. Nov 20, 2015 at 8:28 AM
    #55
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Most BB installers...... most or SH!T, Your better off taking the time and learning to do it yourself imo.
  16. Nov 20, 2015 at 8:47 AM
    #56
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
  17. Nov 20, 2015 at 9:00 AM
    #57
    SRC
    Shawn
    Guelph, Ontario
    2017 DCSB OR
    Here's an update from my install:
    I didn't need the Antenna adapter or any harness for the steering wheel controls. I just wired in the steering wheel controls as I noted in my last post and programed them in the head unit.
    I also used a 2012+ trim kit in my 2010 which looks a lot nicer IMO.
    The unit has been great so far.
  18. Nov 21, 2015 at 2:47 AM
    #58
    airrage
    airrage Well-Known Member
    Myrtle Beach, SC
    2006 Tacoma Prerunner SR5 DCSB
    17X9 Gear Alloy Rims, BFG KO2's , Android Radio, 32" LED Light Bar in Bumper, LED Bed Lights,
    I have the same radio in my 06. Just a warning if you use a scoche kit the volume knob is a pain and barely reachable. I will take pics to show what I mean. Radio is awesome though. Debating on trimming the bezel or just getting a new radio with touch buttons! I got the whole kit with front and rear cameras, Also I put the GPS on the of the Headunit which is magnetic and its only plastic above so nothing is really blocked from signal. Works great!!!!
    Kturner23 likes this.
  19. Nov 21, 2015 at 3:55 AM
    #59
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    Do you need a trim kit for the 2012+ if the stock radio is removed? I'm a little confused about that...doesn't any double din receiver fit into the stock trim? Thanks
  20. Nov 25, 2015 at 9:31 AM
    #60
    GTACO
    GTACO GTACO
    Gabriel
    Murrieta, CA
    07 PreRunner
    Camburg Spindles, Total Chaos UCAs & LCAs, Fox 2.5 c/o front, Fox 2.0 rear, All Pro 3" leafs, Dumped Borla muffler, AFE intake, DTF front bumper, Demello rear bumper.
