Angled Washers - CB Antenna Ditch Mount
Discussion in 'Technical Chat' started by MikeyMcFly, Jul 10, 2018.
  1. Jul 10, 2018 at 6:35 PM
    MikeyMcFly
    MikeyMcFly [OP] This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I don't know the best location to place this question, so I'll see if I can get a reply here.
    I've got a pair of CBI ditch light brackets for my truck. Currently I'm only using the driver's side for a CB antenna mount for my Firestik. I'm working through some grounding issues, but that's independent to my question here.
    [​IMG]IMG_0764 by Mike M, on Flickr
    [​IMG]IMG_0763 by Mike M, on Flickr
    Due to the angle of the bracket my CB mount is slightly crooked in that the antenna cocks forward and to be honest, looks a bit goofy. I'm thinking if I drop down to a 3' Firestik over the 4' I have it will be a little less obvious, and I don't anticipate using the radio enough for this to be an issue regardless.
    That being said, any ideas on how to get the antenna to sit straight. I was thinking if I used a pair of angled washers in the same orientation, I'd be able to get it to sit at the correct angle and still be able to tighten down the antenna and get a solid ground. However, I don't even know where to start to find angled washers. A quick search on Amazon shows 30 degree ones, but I can tell that would be entirely too much tilt back towards the rear of the truck.
    I'm reluctant to try to bend the bracket a it's a VERY stout piece. I like the hood bracket as I don't have to worry about using a NGP antenna and mess with the tonneau. I had a NGP antenna with a bed mount on the last truck and I could never get a good SWR / connection.
    Thanks!
  2. Jul 15, 2018 at 6:10 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    The proper name for what you're looking for is a Leveling Washer. https://www.mcmaster.com/#standard-washers/=1dq1wit
  3. Jul 16, 2018 at 9:34 AM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Could you slide a washer under the front of the bracket where it mounts to the truck, to tilt the whole bracket to the back? If so, you can probably adjust the tilt with different thickness washers. Might need a longer bolt depending on how much thickness you have to add.
  4. Jul 19, 2018 at 10:36 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Ahhhh McMaster to the rescue. Great place to buy stuff.
    Even better idea. Just shim the mount level. You can also buy shims from McMaster :cool:. Or a simple washer will due.
  5. Jul 20, 2018 at 3:25 AM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Yeah. I look up stuff on McMaster all the time. There prices are usually high and shipping prices are high too, but if they have what you want/need, and you don't want to shop around they're great.
    Fastenal is another good place to search for hardware. They've got brick and mortar stores you can go to as well.
