Angry angry!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kasey200, Aug 3, 2009.
  1. Aug 3, 2009 at 10:38 PM
    kasey200
    kasey200 [OP] Well-Known Member
    south dakota
    07 TRD Dboubl Cab Longbed
    3" toytec, 285 BFG AT's
    I had to hit the road for work today so i had the express lube change my oil last night. they apparently drained the transmission and added 5 or so quarts to the engine without checking the dipstick. soooo...... (this is amazing)....... 450 miles later traveling at 75mph...... drive and 4h gear quit working!! i limped into the nearest gas station in the middle of nowhere in South Dakota to check it out. (about 2 miles) This is when i noticed that the tacoma's don't have a dipstick for the trans. I pulled the motor dipstick and the oil was about 1/2 way up the stick!! I figured i needed to add oil to the trans and i had no tools so i asked the gas station if they had any i could borrow and all they had was a set of needlenose pliers. i grabbed some cheap shitty ATF and a paper funnel and set out to figure out how to add oil to the trans. the only way i could figure to do it was to remove a line from the trans cooler and dump oil down the line. (it was like trying to pour down a straw). it took 45 minutes to get it to take 2 quarts of oil. i hit the road again to get to the nearest dealership to drop it off and now it works flawless?!?! it is beyond me whether or not anything was damaged. i drove another 100 miles without a hiccup. i just got to my hotel and plan to take it to another express lube in the morning to have them flush the trans and change the oil again. (all of this took place after dark). what approach should i take with the shop that messed up? sorry this is soo long but it's late, i'm pissed, and tired. sorry again but i had to vent!!
  2. Aug 3, 2009 at 10:39 PM
    kasey200
    south dakota
    one more thing........ how in the world did it make it 450 miles with no issues????
  3. Aug 3, 2009 at 10:43 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You are a brave man, sir. I wouldn't even let them set eyes on my truck, and for the very reason your problem occurred in the first place.
    Hope you get all worked out!
  4. Aug 3, 2009 at 10:46 PM
    SC4333
    Grant
    FL
    If they pulled the plug on the transmission pan, which I am assuming they did, you would have only lost a small amount of fluid, not the whole capacity. You probably lost somewhere between 1/2 to 1 1/2 quarts of trans fluid.
    Now the only question is, why did they not think something was wrong when red fluid came out of your "engine?"
  5. Aug 3, 2009 at 11:24 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I will NEVER take my truck to any sort of those shops. If I don't have time to do it myself.. there's something wrong. Changing the oil takes less than 20 min.
  6. Aug 3, 2009 at 11:37 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Yeah oil changes are really easy! You have time to sit at the computer? So you have time to change your oil!
    The only thing don't like about the oil change deal is that Toyota put the filter on top of the engine. (Makes a mess) I'd prefer it to be on the bottom.
  7. Aug 3, 2009 at 11:46 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    What retard drains the Transmission? :anonymous:
  8. Aug 3, 2009 at 11:47 PM
    DdayIsNear
    DdayIsNear Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    bang a hole through the top of the filter before removing it, preferebaly with a punch or flat head screwdirver, then you will will have less leak when you remove the filter.
  9. Aug 3, 2009 at 11:48 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Fort Wayne Indiana
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    Man ur lucky, my brother took his 99 4Runner to jiffylube for an oil change. They pulled out the trans cap draining nearly all the oil then put the cap on so wrong that it fell off few hours later on a steep hill leaving a big ass trail of transmission oil down the road. Transmission seized up. We almost sued but it wouldnt hold up in court
  10. Aug 3, 2009 at 11:51 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    that's a good idea... I'll have to remember that one for all the times I've used countless rags to clean it up!
  11. Aug 3, 2009 at 11:55 PM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Did you ever notice under your truck if you have oil splattered from the tranny on? You know... the wind blowing it back while driving. Perhaps you didn't lose any on the road and only when you were stopped at home before taking off. Food for thought. Look for evidence that something was done wrong. What are the chances you have the paperwork on you from yesterdays service before walking in the other business. Good luck... that sounds like an uphill battle youre about to approach.
  12. Aug 4, 2009 at 4:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I wouldn't be saying that just yet....... There could be all sorts of damage, you're just not seeing the results yet.
    I'd start doing some research and get information on how you can sue them for fucking up your truck.
    I'd never take my vehicles to anywhere but dealerships or trusted mechanics. Just goes to show how frigin stupid these people are.... they drained the damn fluid and never noticed it was ATF instead of regular oil.
  13. Aug 4, 2009 at 4:36 AM
    Deuxdiesel
    Deuxdiesel Well-Known Member
    SE MI
    '12 Silver Streak stocker
    Wow, sorry about your experience, hopefully there is no long term damage. I'm nervous enough letting the "factory trained" monkeys at the dealership touch my truck, let alone one of those places. Live and learn.
  14. Aug 4, 2009 at 5:40 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I thought about doing this but am worried I might flake off some metal from the filter and it drains into the engine as the oil drains out of the filter.
    Find out from the dealer how much oil is left in your tranny case. If it did not all drain out, then you are probably OK. If there was only 1-1.5 qts in there (from what you poured in), then the troubles will come prematurely down the road (literally :D).
    I would talk to your insurance company and ask the opinion of the dealer. Is the Auto Lube shop's service warrantied?
    That sucks and is why I will NEVER take my vehicle to a quick lube shop. The last time I did (4 years ago), I opened the hood 2 days later to find a rag and a wrench sitting in my engine compartment :eek:. Very lucky it didn't bounce around and get caught up in the serpentine belt.
  15. Aug 4, 2009 at 6:06 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    Since the Past 5 years i have changed the oil on all my cars and my parent's car my self its the most efficent and the safest way of changing oil.... Once you know how to do it, you would want to do it yourself.
  16. Aug 4, 2009 at 6:17 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    If you dont change it yourself than have the dealer do it. You'll have a much easier time getting a replacement trans out of a dealer than you will out of " Jiffy Lube "
  17. Aug 4, 2009 at 6:37 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    I pay a dealer $20 to do it and get a free car wash.
  18. Aug 4, 2009 at 6:48 AM
    Slypted
    Slypted Well-Known Member
    Frank
    NJ
    08 Tacoma SR5 4x4
    Smiitybuilt nerf bars, Hunter bull bar w/ KC hilights/ Toy-tec 3" spacer, AAL lift, LR UCAs, Helo he842 16x8 Wheels, BFG KM2 285x75x16
    My mom had a bad experiance with one of those places once. Apparently when they changed her oil they never torqued the drain plug down. Shortly after her check engine light came on and she pulled over to discover it fell out and she had no oil. They ended up buying her a brand new engine for fear of getting sued.
  19. Aug 4, 2009 at 6:55 AM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    You pose a good question :rolleyes:
  20. Aug 4, 2009 at 7:01 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Thank you for sharing that. It definitely confirms the general consensus to keep our vehicles far away from those cheap places. And, sorry you had to go through that unpleasant experience.
