ANNOYING ALARM CHIRP IDLE/STARTUP
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OhYouKnowTheThing, Aug 26, 2021.
  1. Aug 26, 2021 at 11:53 PM
    OhYouKnowTheThing
    OhYouKnowTheThing [OP] New Member
    JOE
    2021 TACOMA TRD SPORT
    CUSTOM AFTERMARKET GRILL, 35 INCH TIRES, FUEL WHEELS, CATBACK EXHAUST.
    After three days I am loosing my mind. Dealership doesnt know what it is, keep in mind this Taco has 7k miles on it and it's a 2021.
  2. Aug 27, 2021 at 2:52 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    My 2021 Taco does not make those sounds and I have 5000 km on it. Almost sounds like something is vibrating when starting but when it does it every time you hit the gas pedal that is something else, Hope they figure it out cause that would be annoying.
  3. Aug 27, 2021 at 3:23 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    In the first video, it’s doing it when you press the accelerator and not just at start up.
    There’s got to be a short or some type of cross over between the two systems. But then again, I have no idea :D
    Seems like one of those dealership too-tedious-for-us-to-help-you-out kind of things.
    Maybe some electrical guru will pipe up with some avenues to start with. Good luck.
  4. Aug 27, 2021 at 3:36 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    Sounds like an aftermarket alarm. Like the older viper ones. My truck has never made a noise similar. Lots of others, but not that.
    did it just start doing this. How long it been going on. And have you wired anything in?
    BSFord likes this.
  5. Aug 27, 2021 at 3:47 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Do the 3rd Gen Tacos have an alert for RPM/speed that you can adjust?
    I worked at Lexus and when either the RPM or speed reached a set (by the owner) value, it would flash the instrument display and possibly also beep.
  6. Aug 27, 2021 at 3:57 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    In mine you can set a speed limit but that's it. But I have a 2017 and not a 2021.
  7. Aug 27, 2021 at 5:45 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I think you're on to something!
    OP any aftermarket electrical doodads added? I would start there.
    kahanabob and BSFord like this.
  8. Aug 27, 2021 at 6:21 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I’ve installed many viper alarms in my time. I’m almost positive this is the “disturbance alarm” that is going off when the engine shutters….either by starting or revving enough to cause the truck to move. Look for fuse taps on the fuse boxes and t-splices under the dash…most likely just upstream of the OBDII connector.
    if you turn the ignition on but don’t start the truck, slam a door or tailgate pretty hard. Or the hood. Try to jar the truck and see if it chirps.
  9. Aug 27, 2021 at 6:32 AM
    Riotfunk
    Taco TRD off road
    Unplug the tss sensor quick and see if that does anything
  10. Aug 27, 2021 at 8:19 AM
    OhYouKnowTheThing
    JOE
    So far I checked my connections and it’s still doing it. As far as adding any aftermarket items recently two months ago on last week on June I installed new headlights on my truck. But the chirp noise started four days ago on Tuesday the 24th.
