annoying click when opening the driver's door... now passenger door also
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slick-Willie, Jun 29, 2015.
  1. Jun 29, 2015 at 7:14 PM
    Slick-Willie
    Slick-Willie [OP] Active Member
    Bill
    AZ
    05 Tacoma
    none
    Hey All, I have a very annoying click when i open the driver's door, i have sprayed the door stop rod? with a shot of wd-40 and then a couple of months later i hit it with some silicone spray lube... this does not help. anyone else have this issue and how should i go about fixing it. am i even close in where i'm looking for the noise, could it be a door hinge? Thanks.
    2005 speedway blue, TRD 4 door 111.000 miles
  2. Jun 29, 2015 at 7:20 PM
    RustyBlue
    RustyBlue Meh...
    Bryan
    Dayton, Ohio
    06 A-Cab TRD Off-Road 4x4
    mine does the same. its the that plastic rod thingy at the hinge on mine making the noise. Needs some of that white greasy goop that won't run off with age/heat/gravity. WD40 will only be a temp fix. you need something with substance.
    If its a metal sounding click, then you could have some rust or crud in the hinges. PB blaster would be good for the hinges.
  3. Jun 29, 2015 at 7:59 PM
    Slick-Willie
    Bill
    AZ
    05 Tacoma
    none
    Thanks, i will pull the door stop rod off and lube it with some white lithium grease.
  4. Jun 29, 2015 at 8:03 PM
    RustyBlue
    RustyBlue Meh...
    Bryan
    Dayton, Ohio
    well we just helped each other, because i couldn't remember what that stuff was called for the life of me :cheers:
    Slick-Willie[OP] likes this.
