Annoying clunk in my front end
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ronnie4X4, Oct 4, 2015.
  1. Oct 4, 2015 at 2:39 PM
    ronnie4X4
    ronnie4X4 [OP] Well-Known Member
    Ronnie
    2014 Black Tacoma TRD
    Upgraded sound system
    Here's the rundown:
    Shortly after lifting my 2014 Tacoma TRD with a 6 inch coilover kit and getting it aligned, I started to notice a very annoying clunk in the front end when I hit bumps. It happens in both 2wd and 4wd and is more pronounced on more aggressive terrain. The clunk sounds like a low end thud and it kinda feels like someone is underneath the truck pounding on the floorboards with a rubber hammer.
    Here are the possibilities I've ruled out so far:
    • Sway bar bushings
    • Steering shaft butting up against the rag joint
    • Zippy tie mod needs done
    • Loose suspension components
    • Loose carrier bolts
    • Loose battery
    I hopped under the truck and the inner CV joints have what seems to be an unusual amount of play in them when I shake them. This video (not my video by the way) demonstrates what happens when I shake those joints with my hands:
    https://www.youtube.com/watch?v=K3aC2KGEgWE
    I'm thinking this is the source of my clunk; what do you guys think? If you read the comments posted on the above video, you'll see that those guys are saying it's the needle point bearing inside the front clamshell.
  2. Oct 4, 2015 at 2:42 PM
    Jp450
    Jp450 Well-Known Member
    Vegas
    15 TRD OR
    ADS Suspension MCM FAB UCA'S Deaver leafs
    Might have to much preload on coilovers in turn not enough down travel causing noise over bumps.
    Kyitty likes this.
  3. Oct 4, 2015 at 3:04 PM
    ronnie4X4
    Ronnie
    Holy shit, you may be right. I see 2.5 inches of threads showing above the coilover adjustment ring.
  4. Oct 4, 2015 at 5:05 PM
    Jp450
    Vegas
    15 TRD OR
    That is alot. Try reducing that. Hopefully that's fixes that noise.
  5. Oct 4, 2015 at 6:15 PM
    ronnie4X4
    Ronnie
    Here's a pic. I'm thinking I'll loosen the collar to reduce the amount of threads showing above it by 1/2. Can you see any problem with that?
  6. Oct 4, 2015 at 6:20 PM
    Jp450
    Vegas
    15 TRD OR
    No that should be ok. Just make sure you do both sides equal. Then give it a drive. To see if noise went away. My suspension guy told me you want 2 inches of down travel at least. So take a measurement with the truck on its own weight from hub to fender. Then jack it up weight off wheels full extended measure again from hub to fender. Should have a difference of 2 inches.
  7. Oct 4, 2015 at 6:33 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    if you had an alignment maybe they didnt tighten LCA cams did you check those?
  8. Oct 4, 2015 at 7:01 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Check the 4 bolts in crossmember under the transmission.
    sr5vic likes this.
  9. Oct 4, 2015 at 7:02 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Mine were loose and perplexed me for 9 months thinking it was a loose component in the front end.
    sr5vic likes this.
  10. Oct 4, 2015 at 7:19 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
  11. Oct 4, 2015 at 7:24 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    the crossmember going under the transmission / transfer case - there are two bolts that connect it to the tabs on either frame rail. My truck would pop and creak moving forward or backward and I thought it was eithe the coils or LCAs. But I tightened those 4 bolts and the noise stopped.
    sr5vic likes this.
  12. Oct 4, 2015 at 7:25 PM
    ronnie4X4
    Ronnie
    Thanks guys, I will check the LCA cams and the cross member bolts tomorrow. I wasn't able to adjust the preload on my coilovers because somehow the adjustment screw that locks the collar to the thread is in the back where I can't get to it. I wonder how the hell my mechanic managed to lock the collars??
    Also, I did the measurements Jp450 recommended and here's what I found when measuring fender to center of hub cap:
    25.5 inches with the truck resting on the wheels
    28.75 inches with the truck jacked up
    So that's a difference of 3.25 inches (not 2 inches). Looks like I need to take 1.25 inches of preload off the springs... Now if I can just get to that damn allen screw that locks the collar to the threads.
  13. Oct 4, 2015 at 7:26 PM
    ronnie4X4
    Ronnie
    Gotcha. How many foot pounds of torque should be on those bolts?
  14. Oct 4, 2015 at 7:50 PM
    Jp450
    Vegas
    15 TRD OR
    Those numbers look good. I don't know how old your fox coilovers are but there are some threads on here with guys saying their fox coilovers make a clunking noise. Are you bracket lifted? Or mid travel?
  15. Oct 4, 2015 at 8:32 PM
    ronnie4X4
    Ronnie
    Bracket lifted. The lift kit, including the coil overs, only has 6 weeks of use. This clunking has been occurring for the last 4-5 weeks. It's really getting on my nerves. You'd think that when you drop $3.5K on a lift kit (without the installation), issues like these wouldn't be occurring so soon. Fak...
  16. Oct 4, 2015 at 8:37 PM
    Jp450
    Vegas
    15 TRD OR
    Are still running stock uca's? Doesn't look like it in picture but can't really tell. Some guys on here remove the sway bar also, some say that fixes it. I had a bracket lifted Titan and it would make that noise but it was my stock uca hitting the coi bucket.
  17. Oct 4, 2015 at 8:39 PM
    ronnie4X4
    Ronnie
    No, I'm rocking the new UCA's that came with the lift.
  18. Oct 4, 2015 at 8:41 PM
    Jp450
    Vegas
    15 TRD OR
    Cool. Well yank the sway bar out that bitch and give it a shot. I took the sway bar off when installing my mid travel set up and rides awesome still safe at highway speeds and ride is smooth on road and especially offroad
  19. Oct 4, 2015 at 10:49 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    I had this same issue. As stated, check your tranny mount bolts.. they're supposed be something like 30ftlbs but I took mine to about 50ftlbs
  20. Oct 5, 2015 at 11:37 AM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I don't know...but mine were really loose so I made them tight.
