Annoying issues with Comcast
Discussion in 'Technology' started by Chickenmunga, Sep 28, 2011.
  1. Sep 28, 2011 at 10:55 PM
    Chickenmunga
    Chickenmunga [OP] Nuggety
    Hillsboro, Oregon
    08 TRD Offroad DC 4x4 (read the build)
    I just moved to my apartment last week and got Comcast because I couldn't find a competitor
    I have the following brand new gear:
    Motorola surfboard SB6120
    Cisco/Linksys E4200
    I just tried uploading a 27kb file to photobucket and it craps out at 94% every time.
    I do a speed test and it dies before the upload can begin. speakeasy, speedtest, cnet, you name it, all the same - consistent 20-22 mb down, craps out on upload test. I tested on both my Win7 machine and my Ubuntu machine, both with and without router attached.
    I get a consistent 75ms ping on stuff like Day of Defeat
    MW2 thinks my connection is fine
    Anyone got clues? Any other ISPs I should consider? I found CenturyLink provides 1.5/896, which doesn't sound any better.
  2. Sep 28, 2011 at 11:06 PM
    J0hnMata
    J0hnMata Well-Known Member
    Orange County
    09 PreRunner
    BHLM, bilstein 5100's, satoshi grillcraft grill, k&n cold air intake, tinted windows all around, interior map and dome light led's, hid fog lights and headlights, yellow fog light lenses, black lower valence.
    Sucks man i work for time warner out in CA which is basically what you have but i only do field collections and disconnections so i can't even help. If all else fails call and complain so they credit your bill since the service isnt working and set up a trouble call!
  3. Sep 28, 2011 at 11:25 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    I'm having problems with their digital cable right now and it's annoying the hell out of me. Internet is fine though but I'm looking for a cheaper provider right now. I only got this with gaming in mind but it's getting pricey.
  4. Sep 28, 2011 at 11:33 PM
    Chickenmunga
    Hillsboro, Oregon
    If you have any chance, always go with FIOS. I had a rock solid 15/5 link in Oregon.
    Just tried to upload youtube for fun... doesn't get past 0%
  5. Sep 28, 2011 at 11:38 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    x2 to this, maybe they are having problems in the valley idk, but im not a fan of them. I did manage to get them to give me about 400 ft in tv cables tho :rolleyes:
  6. Sep 28, 2011 at 11:47 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    They may need to check your signal. I would have their service tech come out. Or your modem could be bad. I've had similar issues before & they had to boost my signal.
  7. Sep 28, 2011 at 11:59 PM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Fios?
    Your problem might be a weak signal but idk why you only have problems uploading..
  8. Sep 29, 2011 at 12:49 AM
    genxer36
    Sean
    Bethlehem,GA
    FIOS(Verizon) is the ultimate highspeed internet, but only available in limited markets.:( It is run through fiber optic(speed of light), instead of coax like cable internet, or copper with phone lines for DSL.
    http://communication.howstuffworks.com/fiber-optic-communications/fios.htm
  9. Sep 29, 2011 at 1:45 AM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Ah thanks for that info, I'll look into it.
  10. Sep 29, 2011 at 4:17 AM
    HogTaco
    HogTaco Well-Known Member
    Northwest Arkansas
    2011 Access Cab 2.7 2WD AT
    Bed Mat, OEM Running Boards, Ultra-Gauge.
    You sound like you know what you're doing, but have you checked your upstream traffic? If a device on your network is zombified, you could be saturating your pipe. P2P apps can also trigger bandwidth throttling for a lot of ISPs. I like tomato firmware on my routers. Easy to see what's going on.
  11. Sep 29, 2011 at 4:35 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    You could have a couple issues. Signal issue since you already bypassed the router and haveing same problem. Also it could be a bad modem these do go bad slot. More then people think. It's not a router issue if you have bypassed it and having same problem. Best thing to do is either take the modem to a service center and get it changed out or call them up and have them come out to you. I don't know if they charge for truck rolls tho.
  12. Sep 29, 2011 at 5:11 AM
    rollin904
    rollin904 Feather Slinger
    TJ
    Bel Air, MD
    '14 DCSB 4x4
    Yea dude I'd try to get Comcast out there a few times first...I had a lot of issues with my internet when I first moved in to my house, and Comcast was the only high speed option there. I had them replace my line, then I upgraded my internet so I could get the Docsis 3(spelling?) modem. Internet is over 10mbps faster than it even should be...I'm pretty satisfied. I can download on my computer while playing cod on my ps3, no lag whatsoever.
  13. Sep 29, 2011 at 5:12 AM
    rollin904
    TJ
    Bel Air, MD
    '14 DCSB 4x4
    Plus if you bitch about the problems with your service you can get them to knock off some money on your bill, etc.
  14. Sep 29, 2011 at 7:42 AM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Comcast is crap. A ton of marketing and bad management around what could be an actually decent product.
    FIOS is very very good IF the actually have service in your area. A lot of phone companies have begun upgrading their services with fiber optic fairly close to your home. It's not fiber optic to your home like FIOS, but it's still very fast. If you can get FIOS or your phone company has invested in fiber in your area, those are awesome options. I have a CenturyLink 20mb service and it blows away Comcast's service.
    Comcast worked well for games and surfing, but for uploading or serving web pages, it is awful. Their 'speedburst' feature is great if you're downloading a song or whatnot, but used to cause havoc with things like Netflix where you need a consistent stream for hours. IMO, Comcast always seems to be spending tons on marketing and offering loads of bandwidth to the newest customer at the expense of their actual customers. How fkn irritating to have to call them every 6 months and play that stupid game to get a better rate.
  15. Sep 29, 2011 at 7:43 AM
    penguins_cc
    Will
    Bellevue, WA
    Comcast, FTL.
  16. Sep 29, 2011 at 2:09 PM
    Chickenmunga
    Hillsboro, Oregon
    well, i got on the tech chat with "Rojhelou" today who said there's an outage in my area. He couldn't provide me with a timeframe, of course.
    this was the fun part:
    maybe something changed over the years, but SLOW means I can still get things done. FAIL means it doesn't work at all.
    At least it's supposed to be an outage and they answered me quick.
