Annoying P0032 check engine light won't go away
Discussion in '1st Gen. Tacomas (1995-2004)' started by ezatnova, Mar 25, 2011.
  1. Mar 25, 2011 at 4:36 AM
    ezatnova
    ezatnova [OP] Artax
    West Chester, PA
    21 DC TRD OR - Voodoo
    Wildpeak 265/75/16, Headstrong Progressive AAL, 5100's w Emu 885s
    Got a CEL about 2 months ago when I first got the truck. P0032. I was doing a lot to tune it up since it was time for maintenance so I just cleared it and waited.
    It came back 2-3 weeks later. Researched it and learned it has to do with the front A/F (O2) sensor. Replaced that with the true Toyota Denso part to the tune of $160.
    I was shocked to see the stupid CEL come back on yesterday (2 weeks later). You guessed it...P0032 again. Following the factory service manual, I followed the flow chart. Since I knew the sensor wasn't the issue now, I moved along to the EFI relay. I tested that out for continuity and resistance, and operation. It clicked when it should, and tested identically in all situations to the adjacent relay in the fuse box, which is the same part. So, I think the relay is fine. Last step was to test the ECM, and it seems like that tested fine to me too. Got voltage through the pin receptacles that it tells you to test (got 12.2 v). So...that just points me to "replace ECM". Come on! Really?
    I have no ideas what a good used 04 Tacoma ECM runs (or how specific I need to find one (auto vs manual, etc?) but I'm betting it's not cheap. I HATE CEL's, so I really want to fix this, but, if the error really doesn't ACTUALLY matter, and the fix will be a fortune, I may just fix it with black tape! It would really bug me to not have the CEL function to catch new ACTUAL problems in the future, with that "fix" though.
    Any other thoughts on this P0032 and what I can do to try and attack it?
    Thanks
  2. Mar 25, 2011 at 9:23 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    Need more info on truck - mileage, engine, yr, etc.
    Have you replaced BOTH O2 sensors?
    I did my front first & 3 wks later the CEL was back on. Did the rear and no more CEL!
    Get your Denso sensor from Amazon.com for A LOT less than $160!
  3. Mar 25, 2011 at 10:03 AM
    ezatnova
    ezatnova [OP] Artax
    West Chester, PA
    P0032 is only for front sensor (bank 1). The sensor has to be the true A/F sensor, not the cheaper O2. I got mine at dealer cost, at $155. I did find them online for $140 or so, but with shipping it just wasn't worth it to save $2 or so.
    Truck is 04 130k miles v6 auto trd 4x4
  4. Mar 25, 2011 at 5:13 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Clean the MAF sensor my cel kept spitting out o2 sensor codes even after I replaced both, so I just said f it and left it on forever recently clean the MAF and bing light went away once the computer registered and hasnt came back on since
