ANNOYING SQUEAKING/CREAKING SOUNDS!!
Discussion in 'Texas' started by texred73, May 2, 2016.
  1. May 2, 2016 at 8:36 AM
    texred73
    texred73 [OP] Trailrunner07dsm
    brian
    Houston
    07 Prerunner SR5 DC DSM TRD Offroad
    Only the maglight mod,mounted on floor drivers side, billet antenna and have lined all storage under rear seats with rubber to keep the rattling to a minimum.
    I'm going nuts trying to figure out what's causing a squeaking sound when I'm backing up. Sounds like it could be coming from the rear drums, FYI I have 96K on my 2007 and haven't done a brake shoe replacement. Could this be like a wear indicator making this sound, similar to what is on the front pads? Also of note, I will be upgrading the shocks and struts soon to 5100's and I'm curious if the creaking sound I hear when I step onto the bumper could be from the rear shocks or if it is the leaf springs. ( I have the stock leaf pack w/o the AAL TPMS fix) Thanks in advance.
  2. May 2, 2016 at 1:24 PM
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    My 2014 rear leafs squeak when compressed unless I grease them every 5,000 miles. Has nothing to do with the travel direction of the truck though. Parked or moving they squeak.
  3. May 2, 2016 at 6:04 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Check to see if your truck is included in the rear leaf pack recall, may save you some coin. If your leafs are super worn that may be a cause of the noise.
    Uh, 07 is solidly a second gen.
    texred73[QUOTED][OP] likes this.
  4. May 2, 2016 at 7:43 PM
    UBYBC
    2014 Tacoma TRD OR
    Edited my idiocy. Sorry. :facepalm:
    texred73[OP] likes this.
  5. May 9, 2016 at 7:38 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Have you checked your U Joints? When was the last time they were greased if they are greasable? Another thing is the center support bearing, its hard to tell if it is coming from that, but is a possibility. You could be on to something with the rear brakes as well, although they may not need to be replaced, when was the last time they were cleaned and lubed? Usually wont squeal unless brakes are being applied. Leafs don't squeak unless they are being flexed, but even the smallest flex will do it. Remedy for that is power wash between each leaf, then hit them with some lube(wd40, white lithium, aero Kroil, or whatever is handy). Attempt to move u joints up and down and side to side, any movement from the cups is means for replacement, give em some lube while your there. Center support bearing is much tougher to diagnose. Just because the bushing has play in it, doesn't mean the bearing is bad. You have to disconnect the bearing from the frame( two 14mm bolts torqued to 45ft#'s) support the drive shaft, and spin the bearing by hand. If you feel any roughness in the spin, then that bearing may be bad. Of all the things that can squeak, those are the most common. Good luck with the diagnosis, and let me know if you need any help.
  6. May 9, 2016 at 3:31 PM
    texred73
    brian
    Houston
    Never had the rear brakes off to clean them since I've owned it and I don't believe there are any zirc fittings on mine. It's a 2wd if that matters. I will definitely clean the rear brakes, clean and lube the springs as well as check my U joints. I'm about to put new shocks in the rear so I will do al that when I have it up on the Jack stands.
