Annoying Squeeling when driving*** HELP!!
Discussion in 'Technical Chat' started by OverlAnderson, Feb 26, 2019.
  1. Feb 26, 2019 at 7:26 AM
    OverlAnderson
    OverlAnderson [OP] A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    so I have this terrible squeeling noice very high pitched coming from the front of the truck. its starts at about 15mph and proceeds to get higher the faster I go then slows to a stop as I come to a stop (sounds like a tea kettle whistling then as I stop sounds like what the tea kettle sounds like when you open the relief valve). I swear it sounds just like a bad belt but the belts been replaced, pads and rotors are new. I'm guessing its a bad bearing but have no idea where to start.. any suggestions or anyone faced this problem PLEASE HELP!! this shits driving me insane... which is also a possibility due to the fact the truck wont "squeal" when I try and show it to someone.
    :annoyed:
  2. Feb 26, 2019 at 7:29 AM
    tcjacado
    tcjacado Well-Known Member
    Possibly the idler pulley
    Can you take a video, upload to YouTube then post the link here.
  3. Feb 26, 2019 at 7:31 AM
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    that's the thing it doesn't make the noise at an idle only in motion
    tcjacado likes this.
  4. Feb 26, 2019 at 7:32 AM
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    ill mount my gopro under the hood and see what it finds
  5. Feb 26, 2019 at 7:35 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Even though it’s been replaced it may still be the serpentine belt. To check take a bar of soap and hold it on the belt while running. If it’s the belt the sound should disappear. This is not a fix, just a way to see if it’s the belt.
    xxTacocaTxx likes this.
  6. Feb 26, 2019 at 7:39 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Only in motion? Jack it up and spin your front tires independent of each other. You might have a spring clip on the brake pads rubbing. When I did my brakes the first time I did the same thing.
  7. Mar 5, 2019 at 7:20 AM
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    so upon further investigation is not the wear clips on the pads I'm going to replace the bearings in the tensioner pulleys and belt pulleys and see what happens
    wilcam47 and SR-71A like this.
  8. Mar 5, 2019 at 7:29 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Before you throw money at it, check them. Use a piece of small pipe/conduit and put it on the bolt that holds the pulley on. If one is bad, you should be able to hear the difference. Also put it on the alternator case to check it.
    A cheap HF stethascope (sp?) works well too.
  9. Mar 5, 2019 at 7:38 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    make sure you check the heat shield for rubbing on your rotor...Ive had that happen numerous times.
    Tacoma Mike likes this.
  10. Mar 5, 2019 at 7:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    Only at speed, not idle/stopped I'd be checking wheel bearings
    doublethebass likes this.
  11. Mar 5, 2019 at 7:43 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Wouldn't that be a grinding noise?
    What about the shield behind the brakes?
    wilcam47 likes this.
  12. Mar 5, 2019 at 7:51 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    @Mugshot89, is it speed variant or rpm variant. Does the tone just get higher as you speed up or does it go up with rpm and drop when the tranny shifts and go up again?
  13. Mar 5, 2019 at 8:54 AM
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    it seems like a speed variant it starts at about 15mph and whistles then slows as I slow. I don't notice any difference in sound when gears are changed
  14. Mar 5, 2019 at 8:55 AM
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    yeah wheel bearings make a grinding noise. it sounds exactly like a bad serpentine belt squeal so I don't think it would be the dust shields ive heard that noise before after doing some off road trails and that sounds more like a scraping. also I feel like that noise would occur any time the truck is in motion.
  15. Mar 5, 2019 at 8:59 AM
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    bearings arnt that expensive and im at 75k miles so maybe itd be time to replace them anyway or at least repack with grease
  16. Mar 5, 2019 at 9:38 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    How about a vaccum l leak. That small hose at the rear of the air intake assembly.
    That would show up as RPM increases.
    TOMB
  17. Mar 8, 2019 at 11:27 AM
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    1st part thrown at it was a new serpentine belt noise continues
  18. Mar 8, 2019 at 11:28 AM
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    just bought a new idler pully off rockauto we will see how that goes hoping its just a warn bearing
  19. Mar 31, 2019 at 10:26 AM
    Northweston
    Northweston Member
    Weston
    2001 Prerunner Regular Cab 2.7l
    Hey Mugshot, I am having similar symptoms after recently replacing my belts, wondering if you ever got the high pitch noise while driving/accelerating to go away.
    Thanks
    Weston
  20. Mar 31, 2019 at 2:55 PM
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    I haven’t yet man I’ve tried just about everything I can think of going to start putting wd40 on pulleys one by one to eliminate the squeal
