Annoying tranny shift points
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thomasgacia01, Sep 21, 2015.
  1. Sep 21, 2015 at 2:26 PM
    thomasgacia01
    thomasgacia01 [OP] Well-Known Member
    New Mexico
    2016 TRD Sport DCSB 4x4 V6
    First off, I have a 2016 TRD Sport 4x4 DCSB Super White. I absolutely love everything they have done to this truck. Even the ginomo grill which I will be painting black or replacing with some aftermarket parts. The truck drives like my 14 Tundra did. It is very well refined.
    It does feel a bit more peppy than the 4.0 liter. The transmission around town is fantastic. When it's on the highway though, it shifts from 6th to 4th on moderate inclines going around 75mph. It toggles between 6th to 5th on light inclines. Does anyone else find this annoying? I have owned a 2001 and a 2008 taco but both were stick. Is this normal? Please note, I'm coming from a 2014 WRX with over 300 horseys. I'm not even trying to accelerate. Just maintaining speed.
    I was trying to wait for a 6 speed manual DCSB Off Road but the wait was killing me and wouldn't mind an auto for stop and go up the hill to work in the AM. I'm getting around 19.5 mpg mixed with a 1/4 of my 1st tank left. It's not bad for a new engine. I just feel like it's straining when it jumps from 2k rpm to 4500.
  2. Sep 21, 2015 at 2:29 PM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    Is your ECT button engaged?
  3. Sep 21, 2015 at 2:30 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  4. Sep 21, 2015 at 2:34 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    try switching off the over drive & see if that helps
  5. Sep 21, 2015 at 2:34 PM
    txags92
    txags92 Well-Known Member
    2016 DCLB TRD OR 4x4 BBP
    I remember reading a post a few weeks ago about the gear ratios on the new 6spd auto and how the last 2 gears were both overdrive gears. Also, I believe the Atkinson cycle is more efficient at lower RPMs. So they probably geared and programmed the shifts to keep it cruising at lower RPMs most of the time for fuel efficiency, but since the engine generates more power at the higher RPMs, it isn't surprising that it would downshift a bit to get it when it needs it.
    If I recall correctly, the gearing on the 6 spd manual is different and would result at significantly higher rpm than the auto at the same speed when you get into 5th and 6th. Which would probably reduce the amount of shifting needed, but probably results in the slightly lower fuel efficiency of the manual.
  6. Sep 21, 2015 at 2:35 PM
    thomasgacia01
    New Mexico
    It's very eager to shift. It pushes to go faster. The ECT power button has been off all weekend. I turned it on this morning on the way up to work and it just exagerated the hang on the downshift rev. It's definitely never stubborn to down shift. Also never hunting. I love the transmission. Just feels too eager.
    0uTkAsT likes this.
  7. Sep 21, 2015 at 2:36 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    You sure its dropping gears? probably kicking TCC off on light inclines and tcc off and drop to 5th on bigger ones
    1MK and 12TRDTacoma like this.
  8. Sep 21, 2015 at 2:38 PM
    judgeman6970
    judgeman6970 Well-Known Member
    Bob
    Long Island, NY
    I read that a few other guys complained about that also. I would hate that myself. I like the way my '14 V6 Taco stays in 5th on the highway 99% of the time, just like my old '03 Silverado did(4th gear). Problem is most of these "new-fangled" auto's tend to upshift/downshift more in order to squeeze a bit more mpg's....
  9. Sep 21, 2015 at 2:39 PM
    Aussiek2000
    2016 Offroad AC
    One reason i decided against the GM twins. The shift programming is horrendous
    ytmndan and Kysport like this.
  10. Sep 21, 2015 at 2:41 PM
    thomasgacia01
    New Mexico
    I kinda think that these newer trannys are trying to be so efficient nowadays that they're making them work like a CVT. I test drove a 15 corolla for kicks and that trans can suck it. Merging onto the freeways and slight inclines rev the crap out of those engines.
  11. Sep 21, 2015 at 2:42 PM
    Aussiek2000
    2016 Offroad AC
    only going to get more CVT like with the 8,9,10 speed units coming out.
  12. Sep 21, 2015 at 2:44 PM
    thomasgacia01
    New Mexico
    Manual shifts work to a point. I tried that too. It helped stay in 5th til it makes up it's own mind about dropping to 4th. I can predict the drop to 5th and even 4th now. 5th has plenty of power to make it over the inclines but it wants to drop to 4th. It will drop itself into 4th even if you have manually selected 5th.
  13. Sep 21, 2015 at 2:45 PM
    Aussiek2000
    2016 Offroad AC
    Does the DIC display what gear the trans is in?
  14. Sep 21, 2015 at 2:45 PM
    thomasgacia01
    New Mexico
    Yup
    scottalot likes this.
  15. Sep 21, 2015 at 2:46 PM
    thomasgacia01
    New Mexico
    Haha, I could probably make some money on it selling it private party with the current demand. :)
  16. Sep 21, 2015 at 2:48 PM
    Aussiek2000
    2016 Offroad AC
    hopefully someone will come out with a programmer for these trucks once they've been out. Dual injection and VVT and 6-speed leaves lots of performance on the table.
    thecelt likes this.
  17. Sep 21, 2015 at 2:49 PM
    thomasgacia01
    New Mexico
    I'd like a nice protune.
  18. Sep 21, 2015 at 2:50 PM
    Aussiek2000
    2016 Offroad AC
    I love the aftermarket tuning capability my GM car offers. Run a mild-ish tune on the street and a neck snapping, fuel guzzling, tune on the track.
  19. Sep 21, 2015 at 2:51 PM
    Aussiek2000
    2016 Offroad AC
    pisser
    0uTkAsT likes this.
  20. Sep 21, 2015 at 2:53 PM
    Aussiek2000
    2016 Offroad AC
    GM is the same way . Once a car has been flashed, you can't revert.
