Annual OR/WA TSF Camping and Wheeling Shindig
Discussion in 'North West' started by Chickenmunga, Jan 1, 2011.
  1. Jun 18, 2017 at 11:11 PM
    #3721
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Unless someone sets one up for September/October ;)
    tpotnoc and penguins_cc[QUOTED] like this.
  2. Jun 19, 2017 at 12:19 PM
    #3722
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
  3. Jun 20, 2017 at 3:31 PM
    #3723
    Antima22
    Antima22 Active Member
    Anthony
    Oregon
    2017 Tacoma TRD Off-Road manual
    Man looks to be so much fun. If you guys need maybe on the next trip I can bring a trunk full of nice clean woods for you guys to use. I'm still a rookie so no off roading for me yet. Wouldn't mind to come by and have a look since I hit the areas often.
  4. Jun 20, 2017 at 10:39 PM
    #3724
    Chickenmunga
    Chickenmunga [OP] Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Having passengers is always a good time. I am trying to get a bunch of projects in line before I head back out, plus I'm not great at planning (other than this event) until I get on top of things.
  5. Jun 21, 2017 at 9:22 AM
    #3725
    Antima22
    Anthony
    Oregon
    I feel you on that. I do have many projects that needs to be done. Maybe rolling with you guys a few time might help make it happen quicker.
  6. Jun 27, 2017 at 9:42 AM
    #3726
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
  7. Jun 27, 2017 at 12:40 PM
    #3727
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Right rear brake was completely worn, metal-on-metal. Made it a bitch to take the rotor off and I fucked up the wheel cylinder in the process. The left side was a lot easier. I replaced the rotor, pads and springs. Bled brake lines and test drove. I can tell I need to adjust them a little more to firm up the brake pedal but otherwise I'm done. You were right - once I took a side apart and figured out how it goes together, the other side went together quickly. Years ago I remember paying $700 to fix drum brakes and Brake Stop still re-used old parts and fucked up the repair. Fixing the brakes myself AND replacing every part with new only ran $170.
    That other occasional grinding noise we heard was from the steering pump. I'm going to try taking that bastard out tonight and see if cleaning the filter screen helps.
  8. Jun 27, 2017 at 6:59 PM
    #3728
    snowgod06
    Rob
    06 Access Cab
    Yea you can adjust them by hand pretty quick, or just drive forward and backwards awhile. Lol
    It's still crazy to think that your brake was the problem. I can't imagine how the shoe was holding so tight? Maybe water got inside from one of the mud holes, causing a suction effect or something? I figured with metal on metal, the drum would spin. Craziness...
  9. Jun 28, 2017 at 5:42 PM
    #3729
    penguins_cc
    Will
    Bellevue, WA
    Well, removed the steering fluid reservoir and cleaned out the screen (it didn't look too bad). Just as a last resort took out the steering pump and gave it a good look. Replaced the fluid and put it all back together and it sounds a tiny bit better, but still horrible. Got a rebuilt pump ordered that should arrive tomorrow. Hopefully that'll fix the issue because I'm supposed to take the truck camping this weekend.
  10. Jun 28, 2017 at 5:43 PM
    #3730
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Could be your rack and pinion?
  11. Jun 28, 2017 at 5:53 PM
    #3731
    penguins_cc
    Will
    Bellevue, WA
    Really, really hoping not. Replacing the pump is a messy pain in the ass but at least it's not too costly. If it's the rack, I'm gonna say fuck it and drive it this weekend. I'd never get that replaced by Friday evening!
  12. Jun 28, 2017 at 6:06 PM
    #3732
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Yeah I doubt you would. If it helps any my rack that I got from CVJ (OEM reman) was $412 I believe.. under $500 for sure.
    penguins_cc[QUOTED] likes this.
  13. Jun 28, 2017 at 10:02 PM
    #3733
    Chickenmunga
    Keizer, Oregon
    I found you a backup solution
  14. Jun 29, 2017 at 10:52 PM
    #3734
    penguins_cc
    Will
    Bellevue, WA
    Just got done replacing the steering pump. The sound (like two metal spinning discs grinding) during slow turns is gone but there's a lot of creaking noises coming from the rack.
    Shitty thing is that I just had steering rack bushings installed a little over a month ago and I started hearing creaking noises as I was driving home from the shop in Auburn so I figured it was because of noisy new poly bushings. The noises never got louder and sometimes they went away. Now I'm guessing it was the rack starting to go bad. It's not leaking at all. Did you install your rack yourself?
  15. Jun 30, 2017 at 7:14 AM
    #3735
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Yeah mine was creaking badly. I'll see if I can find the video and send it to you.
    I didn't install myself, took mule 4 hours to do. Probably would have taken me 8 lol
  16. Mar 16, 2018 at 8:37 PM
    #3736
    snowgod06
    Rob
    06 Access Cab
    Dun dun dunnnnnnn..... ominous sound. :spy:
    June....
    more details in the coming week :cool:
    penguins_cc, RogueTRD and GetzPayd like this.
  17. Mar 16, 2018 at 8:50 PM
    #3737
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    4x4 trophy challenge?
  18. Mar 17, 2018 at 8:09 PM
    #3738
    snowgod06
    Rob
    06 Access Cab
    If you bring the trophy.... lol
  19. Mar 17, 2018 at 8:46 PM
    #3739
    Skootter14
    Jeremy
    if thats all it takes. . . . DONE!
    lol
  20. Mar 18, 2018 at 8:48 PM
    #3740
    snowgod06
    Rob
    06 Access Cab
