Annual rust treatment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rhowell, Mar 10, 2012.
  1. Mar 10, 2012 at 2:45 PM
    rhowell
    rhowell [OP] Well-Known Member
    Robert
    Canada
    08 Indigo TRD Sport 4x4 DCSB
    -Leather with Heated seats -AFE cold Air Intake -DE-jr Rims -Upper and Lower grills from Black Diamond Fabrication -Light bar behind grill -Hella Black Magic Rallye 1000 lights. -OME lift cw Dakar leafs -LR Upper control arms -Rosen duel DVD headrests -Nfab steps -leer canopy
    Well I just went under my 08 for the first time. I pressure washed the thing for a good half hour and let it dry.
    I was pleased with how little rust. Mostly at the welds and speckled rust. I used two cans of spray on rust converter. What do you all do when it comes to looking after the belly of our trucks.
  2. Mar 10, 2012 at 2:52 PM
    TwzteD
    TwzteD Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    The mechanic i work with reccomended this stuff called marvel mystery oil to me and i spray my truck about one a month with it, its red oil ment to put in you engine but is liquidy, witch makes it easily sprayable, water runs off and rust stays away. if i do see rust i take a wire brush too it and spray it with some paint then a coat of the oil after its set up and hard. He has been spraying his 96 surburban for 12 or more years and there's hardly any rust at all in his undercarriage. if you plan on getting it walmart is cheapest and will spray out of any sspraybottle.
  3. Mar 10, 2012 at 2:57 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Work at a aircraft repair station so i use Aircraft corrosion preventative.
  4. Mar 12, 2012 at 2:02 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Dynatrol perhaps?
  5. Mar 12, 2012 at 9:59 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    I just started down the same road. Right now I've been hitting up parts of the truck with Rustoleum rust converter. Once the weather warms up and stays warm I planned on either using the rubberized undercoating or just a black enamel, depending on what the part is. I'm not really sure, I haven't gotten to that step yet.
  6. Mar 12, 2012 at 10:22 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I do not live in or near any states that salt their roads. However, I have lived on or near the beach most of my life. So, even though the rust battle is different, its been an added maintenance item for me as well. What I have always done is spray rust converter at the earlist sight of surface rust if possible, followed up a layer of paint. I am usually under my truck enough to catch spots as they begin, so every now and then I just get under there and spray and hit all the "current spots" or areas. Sometimes its a spot you hit a year or so before that came back. Typically these are hard to reach spots to clean, scrape, etc., or the welds. My trucks have always sold years later looking very clean underneath. No additional oils, etc. But if I was throwing a salty sludge on my under carraige every day, this seems like a good option. I can spot a NE vehicle anyday just be looking underneath. :D
