Another 2005 V6 4.0 1gr-fe Head Gasket Failure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roaming_art, Feb 3, 2023.
  1. Feb 24, 2023 at 11:10 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Please share a link to a video or videos that were the most useful for you ... I fear I may be in this boat soon. nice work!
  2. Feb 24, 2023 at 11:37 AM
    roaming_art
    roaming_art [OP] Active Member
    2005 Tacoma DCLB SR5
    SR-71A and dk_crew like this.
  3. Feb 24, 2023 at 12:58 PM
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    If you send the injectors out for a full refurb they will replace those parts. Thats what I did, they flow/pattern tested them and everything
  4. Feb 24, 2023 at 10:20 PM
    roaming_art
    Who did you go through and what did that cost?
  5. Feb 24, 2023 at 11:29 PM
    point45
    SoCal, OC
    05 DCSB TRD offroad
    RC fuel injection
    Www.rcfuelinjection.com
    Paid $150 plus shipping for 6 injectors.
  6. Feb 25, 2023 at 7:30 AM
    roaming_art
    Thanks! Sent them an email.
  7. Mar 1, 2023 at 8:57 PM
    roaming_art
    Well, I got her running last night for the first time and I'm getting a new code P0328, "Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)", which is a bit of a bummer! The knock sensors are one of the few sensors along with the crank position sensor that I actually didn't touch during the repair job. So, I'll have to drain the coolant, remove the upper and lower intake again and see what I find. Hopefully it was just a pinched wire, or maybe I hit one of the sensors when I was messing with the big coolant tube that runs between the heads, not sure! I have a buddy that has a better code reader as well, I'll have to see if he can give me more info and see whether there are any other codes I'm not seeing. I did take it for a drive though, and it felt good. Idles well, sounds normal, but under load at certain RPM there is a noticeable shake / knock.
  8. Mar 1, 2023 at 11:31 PM
    point45
    SoCal, OC
    05 DCSB TRD offroad
    Double check all the harness connections before you tear into it.
    They can be difficult to click in all the way or the plastic tab breaks from age.
    roaming_art[OP] likes this.
  9. Mar 2, 2023 at 5:12 AM
    zguy1
    zguy1 Well-Known Member
    Midwest
    The harness from the knock sensors terminates at the back of the RH head. Both the knock sensor harness and the RH O2 sensor are on the same bracket. Double check that. See image below.
    roaming_art[OP] and SR-71A like this.
  10. Mar 2, 2023 at 5:31 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I was going to link to your thread haha. Sounds like OP is good to go though!
  11. Mar 2, 2023 at 4:53 PM
    roaming_art
    Not seeing any issues there, I'll try disconnecting and reconnecting them though. I don't recall touching that connector.
  12. Mar 2, 2023 at 7:04 PM
    zguy1
    Midwest
    If you didn't disconnect that harness, don't bother doing so. I disconnected mine during disassembly but I don't believe you need to in hindsight.
    Assuming that code is related to the knock sensors, you will need to troubleshoot the wiring or the sensors themselves. With the heads off, this is not hard to do. With the heads on, it will be challenging. I checked my wiring harness and the knock sensors before reassembly. This does require the harness referenced in the picture to be disconnected.
    Per the FSM, you can test the knock sensors with an Ohm meter. I checked my harness for continuity as I didn't realize that the harness is under tension as soon as you remove the two bolts holding the coolant pipe to the engine block.
  13. Mar 2, 2023 at 7:22 PM
    roaming_art
    I left the coolant line connected on the water outlet side, and only disconnected it from the inlet, pushed the whole assembly away from the flanges to remove the heads. If I can get that pipe disconnected from both the inlet and outlet sides I should have plenty of access to test those sensors and harness right? I don’t know if I have it in me to take those damn heads off again.
  14. Mar 2, 2023 at 7:26 PM
    roaming_art
    I pulled my upper intake off just now leaving the coolant lines attached just to poke around and noticed a little oil around one of my intake manifolds (cab side), I’m going to replace my PCV valve first and see if that could have been a culprit.
  15. Mar 2, 2023 at 8:10 PM
    #35
    zguy1
    Midwest
    I hear that it is difficult, but possible to get to the knock sensors with lower intake off and with the heads in place. The coolant pipe will not come out with both heads in place. At least one head would need to come off.
    Take a look at this thread.
    Knock sensor bad
  16. Mar 2, 2023 at 8:32 PM
    #36
    roaming_art
    Thanks for the link, that led to me finding this video, where the guy cuts the bracket holding those 2 coolant pipes together, then he's able to disconnect the big pipe from the inlet / outlet housing and fish out those sensors with the heads in place. Looks like I have a game plan, and some parts to order!
    https://www.youtube.com/watch?v=pRwMXzAH19w
    Taco 422 likes this.
  17. Mar 3, 2023 at 9:53 AM
    #37
    Brandon###
    Brandon### Well-Known Member
    That’s a pretty slick way of getting to the sensors. Definitely thinking outside the box.
  18. Mar 9, 2023 at 8:25 PM
    #38
    roaming_art
    zguy1 I don't know where you are in the Midwest, but if you're anywhere near the Twin Cities I owe you a cold one! If anyone has this issue in the future, the replacement part is:
    4.0L KNOCK SENSOR WIRE HARNESS 82219-35020
    SR-71A and zguy1 like this.
  19. Mar 9, 2023 at 8:57 PM
    #39
    zguy1
    Midwest
    I'm near Chicago, but if I was closer I would gladly take you up on that beer. It looks like you had a broken wire harness after all. I'm glad you figured out what it was. I had tried to order one of those to be safe when I was doing my head gaskets but it was on a nationwide backorder back in November of last year.
  20. Mar 9, 2023 at 9:08 PM
    #40
    roaming_art
    There are a fair number of them on eBay right now, ~$25. I’m betting I could repair the connections pretty easily but for $25 I’ll just replace it.
    #40
